Page 1 of 17 1234567811 ... LastLast
Results 1 to 13 of 218
    Jan 2010
    Daikin D-BACS Interface
    Does anybody know if the SetupMS3 software is available for an online download? I am also looking for the excel points list that can be configured and downloaded into the D-BACS.
    Oct 2007
    I assume you are using Lon Gateway?
    Apr 2008
    UK
    SetupMS3 is available, but you might want to add your email address to your profile so a good samariton could send it to you
    I was under the impression that the D-BACS came pre-configured with bacnet points and it was just a case of configuring it to your system, but I'm no expert so don't quote me on that...
    Don't be a stupid dwarf. It's not big and it's not clever!
    Amarillo by mornin'
    Quote Originally Posted by picnik View Post
    Picnik, we have an BACnet D-BACS interface that we are having issues with. The daiken rep came out and said that we have to tell the "master" unit what mode to be in. Does this sound right? Is setup MS3 difficult to navigate? What little bit I saw of it didn't seem to bad.
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
    There is no point configuration in the gateway. The excel file is for generating a points list including object IDs and instance numbers. This is typically useful for integrators who cannot autodiscover.
    Xarralu, assuming you have a heat pump system, mode change command through the gateway will have to be sent to the unit designated changeover master. Mode change command will be ignored by units on the system which are not the master.
    Amarillo by mornin'
    Quote Originally Posted by El Presidente View Post
    Thanks, El Presidente. Just needed someone else to say the same thing before I change all of the programs.
    Albert Einstein
    You're welcome.
    May 2010
    Lower Kingswood
    Any chance of sending it to me too?
    Dec 2008
    Hey,
    Picknik, I am also wondering if you can send me SetupMS3... I have had a terrible time getting an up to date version of this software. I currently have SetupDBACS.. It's basically the same as SetupMS3, though much older. The file version is 3.0.0.1, dated 2002.. Anyways, all I need the tool for is to change the BACnet IP udp port number to something other than 47808. I need to use 47811, and this old version of the tool doesn't support it. The current documentation states the need to use SetupMS3.exe I believe 6 > for this. My main problem is getting in touch with our Regional Daikin AC rep in New England. We have several Silver Daikin D-bacs we use to Integrate with BACnet. And have had much success, though I am running into problems using the Default ports on a few jobsites. Any help is appreciated, if you are unwilling to provide the Service tool, do you know who I would need to Call at Daikin AC for this tool? I work out of Warwick, Rhode Island USA..
    Thank!
    Steve
    Greece
    Hi Steve
    If you did not manage to find SetupBACnet send me an email to attach you the software.
    Dec 2008
    Hi Livaldi,
    Thank you for responding, I have returned in a bit and didn't see your reply! I thought I had my settings set to e-mail when I watch this thread!
    I'f you have an up-to-date copy of Setupdbacs.exe thhat would be great,
    My email is: Removed E-mail Address
    I appreciate your time! Thank you
    Please put email in your profile
    Mount Airy, MD
    Quote Originally Posted by ssorel View Post
    Hi Livaldi,
    ssorel,
    Should you have you're email alert now setup, you need to place you're email address in your profile so people can contact you
    Greece
    Hi steve
    You will receive an email from sendspace. I attached all the documents and programs that i had for DAIKIN D-BACS.
    Hope that these will help
