Page 2 of 17 FirstFirst 12345678912 ... LastLast
Results 14 to 26 of 211
    Apr 2011
    adelaide south australia
    hi to all
    im new to this
    does someone have the setup MS3 software they can email to me
    i am trying to discover the bacnet points on a DMS502B51 WITH A TRIDIUM jace 600
    using bacnet/ip, and it cannot discover this daikin box. perhaps it needs to be enable with this software
    Daikin dont know what im talking about?
    any help is much appreciated
    Stan
    Stan,
    Can you ping the gateway but not discover points? Are you on a different subnet than the gateway? If so the gateway might have to be setup as a foreign device.
    Pres
    Apr 2011
    yes i can ping it
    but it wont discover
    What IPs for the jace and the gateway? I'll send you the setup tool.
    Pres
    Presidente, could you send the setup tool to me as well?
    thanks.
    amigo, check your mail.
    Pres
    Gracias.
    Apr 2011
    Thanks much appreciated
    I'm using a web /jace600 with bacnet over ip and have the second port enabled with the ip address of the Daikin bacnet box 192.168.0.1 which is the default ip address
    I can ping the Daikin box directly through the pc however the Jace can't discover anything when connected in!
    All I want to see weather bacnet is enabled in the Daikin box and if so then the problem possibly is with the jace.
    So a start is to see with this software if bacnet is enabled??
    Thanks again
    Regards
    Stan
    De nada and you're welcome.
    Ok, what's the IP address of the Jace? It will have to be 192.168.0.X if the gateway is left at default IP of 192.168.0.1 without enabling the gateway as a foreign device.
    If it is on a different subnet, say 192.168.1.1, foreign device will have to be enabled inside the gateway and this IP address must be put in so the gateway can send out a request to be added to the BBMD foreign device table.
    BACnet does not need to be enabled. As long as the battery backup switch is turned on and it has an IP address, it is ready to rock. Is the VRV system already connected to the gateway? If not, you will get no points.
    Pres
    May 2011
    Please for the love of everything that is holy send me the setup tool too.
    Getting this from Daikin has proved to be more difficult than pulling 5 girls home from an FHM event.
    Thanks in advance. my email address is in my sig
    Jun 2011
    Is there any chance someone could send me SetupMS3? I can't get a response from Daikin and really need this tool. Thank you.
    threefiddy, check your mail.
    Pres
