Results 1 to 13 of 14
Thread: CVHE
    North America
    CVHE
    Just pumping out some CVHE's and guess what the charging valve stem has broken off. Any tricks to opening the valve with the chrage still in the machine.
    Nov 2007
    I am unsure myself
    Quote Originally Posted by hvacr View Post
    If you are sitting in a vacuum I would just change it on the fly.
    Quote Originally Posted by mustardman View Post
    gotta be fast though...
    Time to get my nerd on!
    ottawa canada
    Ditto Jayguy. Just get yourself a 1/2" ballvalve and nipple, take the handle off the valve make sure its in the closed position and do a quick switch with it in a vacuum . Takin the handle off means you can spin it in quick .
    Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
    Nov 2007
    I am unsure myself
    Quote Originally Posted by jayguy View Post
    I agree with that probably should have put it in my post huh?
    windy city
    ditto, on the fly, and iffen it's not in a vacuum, push some cold R718 thru the cooler bundle
    Quote Originally Posted by heavymetaldad View Post
    the reason i like using R718 is because you can still vent it if you put in too much or if you have to make a repair.
    i also like to sniff a special concoction that i make of 78% R728, 21% R732 and about 1% of R740, R744, R720 and some other stuff that i put in there just for fun.
    and after a big meal i will release a little R50
    North America
    Thanks Jay
    I think we should just add some R-290 and a match then no pumpot is required.LOL
    Thanks Jay
    give me a bunch of beans and i will provide the R50 for free but it comes in small, unregulated batches.
    ottawa canada
    You guys are #@$%ing brutal....???????????????
    windy city
    Forgot to mention octyl alcohol to increase the wetting action
    North America
    The lubricant used in R-50 is it vasaline based.
