    FX graphics - Point Values
    I am using a point that is either ON or OFF. When the point is ON it is in alarm. I am using a BoundLabel to display the value of the point.
    How can I change the color of the BoundLabel to Red when the point is ON ??
    Jun 2009
    StL, MO
    Here's one way.
    Edit the point, look for the Text item. Click the button to the far right (square with three dots). A little box comes up, change the Format to %out.value%
    Save.
    UA LU 562
    If I do that then the value reads: %err:baja:Boolean: out%
    Open the bound label for editing, right click on the word foreground and select animate. Converter type should be "I Boolean To Simple". Choose colors for true and false values. You can do the same for "blink" if you want it to blink when in alarm too.
    ah ... so simple once you know how to do it... Thanks foyler
