    Hope You Don't Need A Blower Motor
    Typical new construction install from about 10-12 years ago...GMP rotbox jammed upside down in a closet corner. Note the 6" bypass pipe mushed into the corner with it. Unbelievably, no missing crimp rings and just a dirty flame sensor. Oh well, next time...
    "Why must I lose to this idiot?!"
    Chess Master Aron Nimzovich, after jumping on the table...
    Vacaville Ca not the prison
    is that a multipoise or is it installed upsidedown? scrach your head and say WTF?
    Apr 2008
    Pluto
    You won't believe how many of those I have seen in apartment complexes. We actually had to remove the furnace to get the heat exchanger out.
    nagakatta yo mou sukoshi de atatakai hizashi abireru, honto wa gutto koraete'ta jibun ni dake wa makenai you ni, nagakatta yo mou sukoshi de atatakai hizashi abireru, hanarete sugoshiita jikan ga samishiku nakatta to ittara uso ni naru...
    Not as lean, not as mean, but I'm still a hardcore, ass-kicking, hard charging Marine! Oohrah!
    Nov 2000
    Eastern PA
    The duct system must be decent and they must really keep the filter clean for a GMP in a downflow position to not have had overheating issues. Otherwise, about par for the course for apartment installs.
    Just a little FYI; if the blower ever sticks or even if the electrical is shut off while that furnace is in the heating mode, you will need to reset an overtemperature reset located on the far back end of the blower housing. You can't see the sucker, but it will keep the furnace from running.
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Quote Originally Posted by RoBoTeq View Post
    Been there, done that. Have serviced hundreds of GiMPS in my time.
    Nov 2009
    Saskatchewan
    Could the customer find a longer filter? Or is that a turn it around and double your fun one?
