Page 1 of 4 1234 LastLast
Results 1 to 13 of 50
    Jan 2010
    Lower mainland bc.
    HVAC techs BC canada, HVAc good carrer?
    Hi all,
    I am currently looking for a steady career that does not have the seasonal flucations as a auto mechanic or requires 25,000-50,000 in tools to work in my trade.
    I have been in the transportation trades in the past and recently done some telecom. The telco work does not pay squat if its only network cabeling ect plus the fact it required huge amount of travel clear across the province.
    The thing with telco installs....is it never brakes to the same frequency as mechanical equipment such as hvac. That means that there will always be more work in hvac.
    I want to know what the outlook for hvac techs are in Vancouver BC and does it require the same physical effot as a auto mechanic. Im not young anymore and more mid life.
    I am looking for a few things if this trade offers it.
    1. Job stability. Want to work year round with little chance of layoffs.
    2. Educations opprotunities to move up the ladder. Can a HVAC move into
    engineering?
    3. Will there be a shortage of HVAC techs in the comming years?
    4. How are hvac techs paid? by the hour? by the install? What is the
    average wage for some one entering this field?
    5. What are some of the best hvac schools in bc?
    I decided against training as power engineer, millwrite, and other areas. Often, these jobs are in tiny towns way outside of vancouver bc.
    Lortech
    Southeastern Pa
    I'll let my Canuk friends like Doug find this post and give you more particular info.
    Generally speaking any trade that does not allow guys to walk in off the street is the way to go nowadays. I had over 30 ASE certs, and most of the guys I worked with in the shop could barely hold a conversation if it didn't involve giant tires or giant mammaries. I don't call that a lifetime job, or at least, not one that I would want.
    Mike Holmes has an entire movement in Canada because so few young people want to go into the trades. He has a point. Someone has to fix all this stuff, and it has to be done right.
    So, unless you have a slap shot that can get you spotted for the Maple Leafs, I'd say go with HVAC.
    Good luck from the son of a Mountie.
    http://www.nbcc.ca/Files/Documents/M...andoutACCC.pdf
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Nov 2009
    Richmond, working under tarps
    i suggest you take the pre-apprenticeship here http://www.jarts.bc.ca/
    All your answers and more will be answered.
    I took it and was hired 3 months later, couldn't be happier with the new career.
    If you have the desire and drive to be the best, and willing to learn on your own time, by hanging out with the elders......... the trade will reward you with more than enough work. and great $$$$
    Oct 2007
    BC
    Quote Originally Posted by lortech View Post
    Hi all,
    engineering?
    Lortech
    You need tons of tools and I would suggest it requires more physical effort than being an auto mechanic.
    Apr 2006
    Yes, it requires more physical effort then an auto mechanic but it also pays better. You get what you earn.
    Apr 2006
    - Year round work is weather permitting, spring and fall are the slow times and should not be considered steady work. Too cold for AC, Too hot for heat=slow weeks that may not be 40hrs
    -don't forget the economic climate, just ask the boys down south how slow it can get: dismal times there
    engineering?
    -2 different schools with 2 different educations, but a mechanical trades background would be an asset if you want to go into engineering
    -HVAC tech could be a plumber, steam/pipefitter, or refrigeration mechanic
    -there will be a shortage of plumbers and fitters average age of local 170 must be in the later 50's and may even be in the early 60's
    -average age of a refrigeration mechanic would in the 40's not a good future and i believe local 516 already has a lot of apprentices out of work. I hear alot of their guys are slow due to being an el nino year(warm winter)
    by the hour
    -Contact UA local 170 (journeyman wage for plumber or pipe/steamfitter is around $35hr plus benefits like medical and pension)
    -UA local 516 (journeyman wage for refrigeration mechanic is around $41hr plus benefits like medical and pension. I believe their pension is between $6 to $9hr into their own plan)
    I made just over $100, 000 last year but I doubt this year will be close to that. Don't forget you must do on call but it is paid at double time rates. At least in the UA.
    Contact Local 170 or Local 516 they both should have in house schooling or BCIT
    It is a good career, but you must budget for the slow times(most don't) and it very hard to get started for a contractor that wants to TRAIN you rather than exploit you for cheap labour.
    Hope this helps you out. Good Luck!
    Nov 2009
    malfunction oops
    Jan 2010
    n/a
    Can get a little slow during periods where weather is mild, ie spring
    engineering? HVAC is huge in terms of the areas you can go into. Yes engineering is a possibility.
    We were told a few years ago that there would be a big shortage with all the baby boomers retiring. Not sure how true this is.
    average wage for some one entering this field? Paid by the hour. If you're in the union, its probably the highest paying trade around, except for maybe the elevator mechanics
    Go to Jarts. They are run by the union, so you have a beter chance of getting a job. BCIT is not considered as good and you may not get the same job leads.
    Lortech[/QUOTE]
    Jan 2010
    Lower mainland bc.
    indy200,
    I did not know jarts had a introductory hvac program. Only if I knew! Is it even possible to work for a company with a mechanical background? I used to be in the aviation and automotive trades at one time. I signed up for the entry level jarts program for public but that does not start until October
    Nov 2009
    yes
    May 2010
    surrey, bc
    this industry is very seasonal. just ask all the mechanics that are not getting
    their 40 hours a week, and its been that way for months with some companies
    as far as school goes, jarts or bcit. they are both private money grubbing
    businesses. jarts started out with the intention of being better than bcit
    but after interviewing with a couple of non-union contractors who stated
    they had apprentices go to both, they implied they prefer bcit.
    the members of 516 are getting screwed because the union is using training
    money to subsidise the apprentices during the school, both union and non-
    union apprentices. thats money that should be used for journeyman upgrade
    courses that used to be available.
    all that aside i think it is still a great trade but no guarantees of permanent,
    full time work from anyone. and most non-union companies are matching
    what the union contractors pay, so a guy could almost just hop across
    the fence to whatever employer is keeping the guys busy.
    oh yeah, as far as the 'pension' which is an individual rrsp plan controlled by
    the union. guys on the lower mainland get $6/hr. i think the island guys are
    higher because the last contract they wanted all the raise on the rrsp whereas all the lower mainland members put it on the wages.
    Calgary AB
    Quote Originally Posted by dalec View Post
    Most accurate and best post so far
    Good luck your going to need it let me know if you need any tools
    Sep 2010
    Re : Indy 2000
    Have you attended JARTS Institute?
    I am on a waiting list at BCIT for HVAC with co op program, but have been contemplating on attending Jarts re apprentice program to speed up the process. Does also anyone know what is the starting wage for HVAC apprentice in BC?
