    Dec 2009
    Toronto Ontario CANADA
    ground source heat pumps
    looking for design info for ground source heat pump for 2500sqft bungalow in southern ontario. Would it be suitable to install a horizontal loop below a 1000sqft attatched garage to provide a more stable ground temp without having to go to deep ? If so what size - length and type of tubing would best suite . I have been told 100ft/ton (home is a new build)
    Lancaster PA
    Moved to residential geo forum
    northern Indiana
    Simple answer is no.
    Not even close.
    I suggest you do research on loops.
    Pacific NW
    Sounds like the obverse of the HO who put his refrigerator in the doorway to garage with the fridge door open to cool the house, then wondered why the garage got hot.
    Dec 2009
    ground source
    My original question is I'm looking for design info. in regards to sizing of horizontal loops for the southern ONTARIO CANADA area.Any info or links would be appreciated.In regards to installing the loop below garage it would be 6ft below grade at the footings not on grade below the slab.
