Thread: N2 LCD Device
    N2 LCD Device
    Hello,
    Does anyone know of a LCD that can do N2 or BACnet/IP.
    We are looking for a device which can display some points from a N2 device or from the NAE using BACnet/IP
    Dec 2006
    What? Who? Where?
    BACnet Touchscreens
    Loytec L-Vis http://www.loytec.com/index.php?opti...d=38&Itemid=19
    American Auto Matrix SBC-SD (MSTP only) http://www.aamatrix.com/products/sbc-sd.shtml
    Delta DHMI http://www.deltacontrols.com/solutio...creens/dhmi-7e
    Amann EWMS View http://www.amann-net.de/produkte/ewms-view_e.htm
    The first two are available over the counter, the DHMI only from Delta partners and the EWMS I don't know availability in the USA.
    I have used the EWMS and DHMI, played with the SBC-SD software and haven't had any experience with the Loytec other then downloading the software.
    If you want any more information send me an email (in my profile) and I'll pass on what I have.
    kontrol out
    Just noticed this was post 303 for me, so I bring you:
    Rule 303
    knotrol out again
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora http://www.youtube.com/watch?v=U7fjDS0jKiE
    Edmonton, AB Canada
    Quote Originally Posted by integrator View Post
    Hello,
    Good day Integrator,
    Depending upon your timeframe and needs, we will soon be releasing the S2UI28 which is a very sweet little wall mounted user interface terminal (TFT LCD with Touch Screen ) that will allow you to interact with the N2 or MS/TP buses.
    http://www.s2innovations.com/content.php?id=52
    Depending upon how you configure the device, it can act as a Supervisory controller for a small N2 bus or as a N2 Slave device. There are also a number of integrated sensors (ambient light level, Occupancy, 2 Binary Inputs, temperature, off-board Platinum 1K RTD, etc) that you may also find useful.
    In addition to the LCD Interface, the device also has a 10/100 Ethernet interface with a mini web-server so that you can "surf" into the device to see the data as well.
    The N2 Slave version will be released next week (first customer bought 100 units) with the N2 Master version 3-4 weeks later followed by the MS/TP version. Since the S2UI28 is field-upgradable you can change the device from the different versions (N2 or MS/TP) by loading in whatever firmware version you wish. So if you require the N2 version now you can migrate to the MS/TP version when you need it...
    If you are interested in more details, just give me a call (my contact info is in my profile).
    Cheers,
    Sam
