    Nov 2009
    Lennox G71 and comfortsense 7000
    Hi All,
    This is my current T-stat setup. Only the R, G, W1, Y1 and C are currently connected. Is this correct?
    Jun 2006
    New Jersey
    Quote Originally Posted by nukepiper View Post
    Hi All,
    That sucks they didn't pull a new T stat wire. 5 wire only gives you so many options with that furnace and stat. Will it work? yes Is it the best setup? nope
    Nov 2009
    Quote Originally Posted by ascj View Post
    What would be the best setup? They still have to come back for a follow up visit to make sure we are happy with everything - I don't know if they would pull new wires but it's worth at try - we spent a lot of money (also had new XC14 3ton installed same time).
    burlington county n.j.
    need more wires or a honeywell iaq thermostat.
    you paid for a variable output furnace but are limited to 2 stage operation the way it is wired.
    Nov 2009
    I am going to have them fix it - but what is the best setup? Also, we want to have the DC motor running continuous - I would like them to set it up for around 1200 (so we can feel the airflow nicely through the vents upstairs - is this reasonable?
