Results 1 to 7 of 7
    IN THE CRAWL SPACE
    I love the metal BDP uses
    The damm boom clips are even weak.
    I aready stripped out the first screw
    Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
    Jul 2009
    In a mechanical room....
    Sounds like someone already dropped a unit on someone head due to crappy steel.
    kc,mo
    sounds right
    use a carrier once and throw it away as cheaply made they are now days.
    newton,mass.
    Quote Originally Posted by thoglow View Post
    Actually that means lifting one unit only ... you see some guys lift two to the roof at the same time ...
    Oh, I have worked on a ton of those units and never stripped out a screw ... it's leftie loosey rightie tightie ... even worse if you are using a drill ...
    Oh, I have had great luck with them as well.
    "Nothing else can poison our culture, corrupt our society or ruin the character of our people like unearned money or unearned opportunity." -- James R. Cook
    "Fooling around with alternating current is just a waste of time. Nobody will use it, ever." Thomas Edison, 1889.
    You have got to be kidding!
    Oct 2005
    Kermit, TX
    You mean it wasn't stripped from the factory? lol
    Actually, that hole should have a clip that slips over the plastic. They tend to fall off. I haven't ever stripped one of those.
    Funny part of the compartment warning sticker is that it needs to be closed when servicing also. Just one of the many things I hate about those units.
    Zach
    newton,mass.
    Quote Originally Posted by aintitfun View Post
    You do love your drill now don't you ...
    Oh, and I am not kidding ...
