Results 1 to 12 of 12
    New England
    iLON-10 Config page access
    I have two iLON10s now that ask for my user name and password (which are the default ilon/ilon) but won't let me in to the config web page. I've done security access resets on them and no change. They still work as RNIs. Any ideas?
    Hampton Roads, Virginia
    What port are they set up for?, go in using the console (hyper terminal) and check your settings. Sorry I can't be more specific but I'm more familiar with ilon 100's.
    Kevin
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    New England
    Unfortunately, there's no console application for the iLON-10. I do a lot of iLON100s too and I've sworn off iLON10s, but I'm stuck with these two.
    SoCal
    Are you sure your PC is on the same subnet? After a security access reset the ilon's iP is set to 192.168.1.222 If you hook up direct, I believe you need a crossover cable.
    Good luck,
    lb
    A hundred million nodes - it's a LON story.
    Yeah, I've had that problem with the iLON-10 before. Turns out it is very sensitive to having other port 80 devices on the network, even if you access it directly on your LAN. You can use a Telnet session (assuming it's turned on, which is the default) to access the console mode. If all else fails, perform a security reset to get back to defaults. Make sure you access it with http://192.168.1.222/config/ to access the config page. Good luck.
    Pacific Time Zone
    What version of IE are you running? From memory there was a problem with IE7 and had to download a patch to actually access the ilon. I want to say you could get part way in as in log in but no further. With firefox it worked fine and with IE6. It's in Echelon's forums/support docs. I'd look it up but I've to to get down the road.
    New England
    I've tried IE 7, IE 8, Firefox and Firefox with IE Tab. Maybe I'll try Safari next. I've performed a security access reset (about a dozen times). I've tried it on my network and through a crossover cable. I get to the authentication page, enter ilon / ilon and get kicked out (authentication failed) every time. I tried telnet, but I swear there's no console application with the iLON10. I'm thinking a hammer might be required.
    Pacific Time Zone
    Echelon Knowledge Base
    Question
    I can ping my iLON10, but cannot configure it using Internet Explorer
    Question Detail
    After a security reset, I set my PC's IP address to one that was on the same subnet as my iLON10 . I can now ping the iLON10, but I cannot configure it using Internet Explorer.
    Solution
    It is likely that you have configured Internet Explorer to use a proxy server to connect to the internet and this is causing the problem. If you need to use a proxy server, you need to disable this feature to access web servers on your PC's local subnet. To configure Internet Explorer correctly, go to the tools/internet options menu, select the connections TAB and click the LAN settings button. Make sure that if you are using a proxy server you have checked bypass proxy server for local address, then save the changes. Perform another security reset on your iLON10, close and restart Internet Explorer and connect to the iLON10 using the URL http://192.168.1.222/config/
    This solution applies to the following products:
    • i.LON 10 Ver 1.0
    • i.LON 10 Ver 2.0
    Last Modified: 10/01/2004
    Solution: KB396
    Question
    Why can't I log in to my i.LON 10 web page?
    Question Detail
    I cannot log in to the home page of an i.LON 10 that has firmware version 2.00.27 using Internet Explorer 7 or 8. Even after performing a security access reset, using the default username and password, I still cannot log in. How can I fix this?
    Solution
    BACKGROUND:
    Internet Explorer 7 and 8 are not compatible with i.LON 10 firmware version 2.00.27, but are compatible with i.LON 10 firmware version 2.00.28. If you attempt to log in to an i.LON 10 with firmware version 2.00.27 and the default username and password with Internet Explorer 7 or 8, the login will fail. Internet Explorer 8 with compatibility mode will also fail. All versions of Firefox and Internet Explorer 6 will work with all versions of the i.LON 10 firmware.
    An i.LON 10 with firmware version 2.00.27 cannot be updated to firmware version 2.00.28. If firmware version 2.00.28 is downloaded to an i.LON 10 with firmware version 2.00.27, the i.LON 10 will typically become inoperable.
    SOLUTION:
    If you have an i.LON 10 with firmware version 2.00.27, use either Internet Explorer 6 or Firefox to access the i.LON 10 configuration Web pages. Firefox is available from http://Mozilla.com
    • i.LON 10 Ver 2.0
    Last Modified: 11/20/2009
    Solution: KB714
    Good call, Crab Master! Saw the first Echelon faq but not the second and most important one.
    New England
    I haven't gotten a chance to get back to this, but I realized that my Firefox would have used IE Tab automatically on the default IP address (which would use the IE 7 engine on my PC), so I actually haven't tried with plain old Firefox. I'll let you know. Thanks for the find.
    New England
    That was it. Thanks, guys.
    Pacific Time Zone
    Thanks for the update.
