Results 1 to 8 of 8
Thread: HVAC Cold Air Intake Freezing
    Jan 2010
    Hello all, I have split level home and in the basement the outside cold air intake has been collecting some ice on the pipe. I was thinking of sealing the exterior of this pipe and insulating it with reflectix. Is this a good idea and will this solve the problem? or just collect additional moisture on the pipe itself?
    Thanx,
    OHLand
    Jan 2010
    North Huntingdon,Pa
    where is discharge pipe terminated in relation to intake pipe termination point?
    Quote Originally Posted by OHLand View Post
    Thanx,
    OHLand
    do NOT do anything before posting some pictures and/or having someone look at it.
    Jan 2010
    Here are a couple of snapshots to show you what I am talking about.
    Apr 2008
    Pa.
    Needs to be insulated. Im curious, is it used for fresh air or combustion air?
    Jan 2010
    Thanks for the reply, I am not sure, I believe it is for fresh air.
    Would Reflectix insulation be the way to go? I don't want to insulate it with non sealed fiberglass insulation like R-6 if it will just absorb the moisture.
    Dec 2009
    Seattle, Washington
    Hello,
    It is your fresh air intake and it seems to be your are just collecting condensation. If you insulate the pipe you will not get the condensation moisture because the change in temperature won't be as great to create condensation moisture. You can try using FSK Insulation but foil to the pipe that way if there is slight moisture if won't be absorbed by fiberglass.
    Jan 2010
    Thanks everybody for the help
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
