Results 1 to 4 of 4
Thread: Lennox Fireplace Question
01-02-2010, 09:30 PM #1
- Nov 2006
- 29
Hi,
I am posting here because I could not find a catagory that was for fireplaces. We have a MPD3530CNM that I have an FBK-100 blower kit on order for. I was looking at my FP and was wondering, can this blower be installed by inserting it in to the box containing the controls by removing the lower grate, or do I need to remove the screen, logs, etc. and lower it into the box? Thanks for any help.
TJ
01-03-2010, 03:13 PM #2
do some research for the install instruction.
http://www.lennoxhearthproducts.com/...BLK-blower.pdf
did it for you, 2 seconds.
01-03-2010, 03:54 PM #3
- Nov 2006
- 29
I found those directions earlier, but I want to eliminate having to pull out all of the grate, logs, etc. if I can. That's why I'm wanting to see if anyone knows if it can be slid in by removing the lower louver. It looks like I may have to remove the control panel inside the lower box, but that would probably be easier than going in from the top, in my case anyway.
01-04-2010, 01:49 AM #4
- Jul 2006
- Virginia
- 378
It is much easier to put it in from the top like the instructions say. You may be able to install it from the bottom, but it will take 3 times longer.
