Results 1 to 13 of 18
    Aug 2008
    Air Intrusion into Living Space
    What are some of the places where cold air (or hot) invades the living space that HO's don't normally think about?
    I've taken care of windows (brand new) and doors (new) and done some caulking. Trying to think where I have missed, some rooms seam chillier than others
    Thanx ahead
    Closet door frames. Ceiling lights in closets.
    Dec 2008
    Buffalo NY
    Thumbs up
    Electrical outlets on outside walls.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Aug 2009
    East TN
    Outlets, switches, wiring penetrations thru the wall top plate, can lights (can be real bad), regular ceiling fixtures, fireplaces, plumbing fixtures, poorly sealed diffusers (registers), floorboards, cable TV and telephone jacks and wall penetrations, etc.
    Aug 2008
    You're so right
    Got a couple of closets that are icebergs, I 'll get on that and and some of the other's mentioned too.
    Now about those outlets. Do y'all suggest the little insulating dooeys that go under the outside plate or simply caulking around where the face plate meets the wall.
    This is good and useful information
    Aug 2008
    Wow, thanx Trog and Kwerty
    Quote Originally Posted by Trog View Post
    ****Sigh****
    Got my work cut out before the cold hits. But need to save some moolah
    Yeah, those pads work well.
    Dec 2008
    Buffalo NY
    Cool
    Quote Originally Posted by AvantGarde View Post
    I used the "dooeys" in my own home and they work great.
    Apr 2008
    Northwest Arkansas via Chicago Area via Straight Up from There on Lake Superior
    Big, big holes where plumbing fixtures come in/out for faucets and drains, typically in cabinets.
    What are "dooeys"?
    Apr 2001
    san jose,ca.
    dooey`s are thinge`s that work better than no dooey`s.
    Jul 2003
    When I had a Blower Door test done, which I believe is the best way to deal with outside air infiltration, we ended up "sealing" places that I would never have considered. One area was the "closet" where the air handler is located, feeding upwards to the plennum & ductwork. Another was the air return chamber, underneath the air handler, which had been drawing air down through the walls, from the attic.
    Another often over looked place.
    Is the stairs to the second floor, if you have a basement. Since usually the stairs are over top of the basement stairs.
    Have the area dark on the first floor, and a bright light shining in the basement stairs. You can often see light around the trim and steps.
    Nov 2008
    SW Florida
    I'm in SW Florida. The ductwork is in the attic as most of the houses are in Florida. I removed the grills and calked around the boots on all of the supplies and the one central return. It lowered the humdity by 5%.
