Results 1 to 2 of 2
    Jan 2010
    Quadrafire Castile Stove ignitor short
    An old version ignitor wire wore and shorted near the ash box. It was replaced with a new version ignitor but I now do not have voltage to it. The stove works fine when manually lit, no fuses appear to be blown. I'm thinking the control panel needs to be replaced unless you guys have another thought on the situation, thanks.
    May 2005
    Madison, WI
    It only has one fuse, so if that is verified with a multimeter, and there is no voltage, then the control box may have been shorted out. I would check the fuse with a meter though, I have seen them look fine, but test bad.
