Results 14 to 16 of 16
    Spartanburg/Greenville South Carolina
    can we say lack of air flow check filters id do a new furnance
    burlington county n.j.
    Quote Originally Posted by james mo View Post
    Replace the ignition control with a universal module, but find out what happened to that lennox heat exchanger before you put another one in. I just don't see them that bad unless there is a serious problem
    probably don't normally see them that bad because the rollout is usually not bypassed.
    at least its an easy hx to change out.
    Jan 2010
    Levittown, PA
    Lennox, Carrier, and York
    Lennox, Carrier, and York commercial heat exchangers come with a 5 to 7 yr warranty. Make sure to check them at about the 7 yr mark. It's almost a sure thing that there will be pin holes starting to form. Check especially at the bottom turn and along the welded seams.
