Results 1 to 13 of 22
    Dec 2003
    Albany OR
    Thumbs up Hey, you might want to check that unit!
    Showed up at a new job site to do a start-up on a Lennox gas-pack. The electrician on site told me that "you should check out that unit, I think something is wrong with it, it keeps tripping the breaker and my wire is good, I bet its a bad compressor!" Funny that that happened since I had not pulled the t-stat wire yet!
    I thinks she needs some "freeze-on"
    Nov 2007
    Maybe he just wired it in to test the breaker....lol
    Dec 2003
    Albany OR
    Quote Originally Posted by hidalgo1301 View Post
    He did just that, and the new one he had to put in im sure will work just as good!
    Jul 2009
    In a mechanical room....
    Did you tell the electrician he might want to check his license out maybe he can wipe his as$ with it, thats all it's good for.
    Oct 2005
    Kermit, TX
    lol
    Zach
    dealt with an electrician in new construction that could NOT wire a trane heater with 2 blk and 2 rd from heater
    he just could not understand the wiring diagram, the blks went to one of his hot wire, the reds went to his other hot wire
    some of those guys worry me
    Saskatchewan, Canada
    wow, dangerous dead short. never even thought of something like that one in my career, only on hvac-talk I guess
    Ct
    Nice. Considering that the breaker would instantly snap back under his finger as he tried to turn it on, I wonder if he went back to check this work and STILL couldn't figure out what he did. That, and i guess the suckply house was all out of red wire that day.
    Merry Christmas all.
    J
    Indiana
    i doubt he really checked his work..just made sure things where tight and not how things were wired
    Nov 2008
    S.C.
    This guy must have been wearing sunglasses, a tie dye shirt and prolly had a lot of knowledge in hydroponics. That right there is hard to believe!
    It's refreshing to pull your head out of the box when servicing a system.
    Jun 2007
    Fort Wayne Indiana
    electrician
    Did a cut in job once. We passed the electrician going to lunch. He said he had the air handler all wired and ready to go. Don't know where he got his card either. He ran the 220 and wire nutted to the low voltage wires coming out of the air handler. WOW
    Washington, DC
    No kidding I found a mushroom fan with the black on one side of the toggle on/off switch and the white on the other side, then the fan was wired in parallel with the switch. I couldn't figure why the switch would not turn it off at first. They must have just kept hitting the breaker until ther inside of the toggle fried enough that it no longer made a short.
    Steamfitters Local 602
    Dec 2009
    Ontario, Canada
    My brother-inlaw called me one day to ask me an electrical question. He had just wired in a new plug at his rental house and when the tenant plugged in her vaccuum and turned it on the motor started to smoke. He wanted to know what he might have done wrong, he said he pulled power from a junction box in the basement. He joined the black wires together, the white wires together and the ground wires together. I told him it sounded okay. He plugged a radio into the outlet and it started to humm really loud before the power switch was even turned on. I said something has to be wrong so I stopped by to check it out. Well what do you think I found when I traced the wires back to the junction box? My brother-inlaw had pulled power from the 230volt central air circuit. So I ran a new wire back to the panel for him to feed the new outlet. While I was at it I found that the hacks who had installed the A/C ran 10 gauge wire from the junction box to the unit, but the supply wire from the junction box to the 30 amp breaker was 14 gauge. So I replaced that piece with 10 gauge and then wrapped the white wires with electrical tape to mark them as hot wires to avoid any future confusion!
    It really is amazing what homeowners and Hack Installers who don't know what they are doing get away with!
    BTW: gotta love family, the brother inlaw gave his tenant my spare vacuum that was stored in his garage to replace the one that was fried! WTF!
