Page 22 of 29 FirstFirst ... 12151617181920212223242526272829 LastLast
Results 274 to 286 of 375
Thread: out of ideas
  1. #274
    Nov 2008
    Meriden, Kansas
    Like lightguy said:
    Quote Originally Posted by LightGuy48 View Post
    See if you can borrow a Fluke ScopeMeter or Graphical MultiMeter (no longer made but still some around) and check the wafeform. On my Fluke Graphical MultiMeter I can also use my amp probe and see the current waveform which can sometimes be handy in troubleshooting power issues, it allows me to see if there is some kind of odd spike in the current draw
    I'd ask the customer to get an electrician who knows power quality to check it out, or offer to bring one in, at his cost.
    Anything I say here is only my opinion. Even if you understood what I said.... What I said may not even be what I meant.
  2. #275
    Sep 2009
    Arnold mo
    Would still like to know if the pool cover motor shared any voltage lines with the air handler motor or do each have a dedicated line and breaker back in the panel.
  3. #276
    Dec 2009
    Buffalo, N.Y
    Quote Originally Posted by tipsrfine View Post
    The Dry-air unit is fed by a small breaker panel which divides its 80 A feed into two breakers. I will find out what feeds that 80 A main and regard any reference to the pool cover feed. I'm not sure if the pool cover made the cut to be included in the generator panel, but I know that the Dry-air unit did, minus the stage two compressor which is interlocked out in the event that back up power is required.
  4. #277
    Sep 2009
    Arnold mo
    Quote Originally Posted by fruecrue View Post
    Could be that sub-panel going bad. Some brands (I don't know which) are notorious for being bad. If the pool motor gets power from it in any way also I'd look hard at the sub-panel.
  5. #278
    don't all electrical items have common voltage lines? at least up to the transformer they do regardless if they have a separate circuit breaker or not.
  6. #279
    Sep 2009
    Arnold mo
    Quote Originally Posted by jayguy View Post
    I guess (at least for you) I should have been more specific and stated do they share any lines after the main elect panel. Fruecrue guessed (no big leap) what I meant & made mention of the 80 amp sub-panel where the motor in question gets its power. He is going to see if the pool cover motor also gets its power either directly from this panel or is tied into it at some point to see if this sub-panel is the source of the problem.
  7. #280
    Southeastern Pa
    You wouldn't mean Fed Pac or ITE would you?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  8. #281
    Dry as a bone Tucson
    Panel schedule (x2)
    A panel schedule would be nice ( plan/actual installation)
    Watchman Nee
  9. #282
    Southeastern Pa
    ........................still pondering........
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  10. #283
    Sep 2009
    Arnold mo
    I may go there wednesday, depending upon another job wrapping up in an efficient manner and light emergency call status.
    I will record and post all electrical data, but if it is a power factor issue, i'm not sure how to identify it...................
    Any suggestions? Dare I ask?
    It's still tuesday.
  11. #284
    Southeastern Pa
    It's still tuesday.
    It's Wednesday. Maybe we will hear something tonight.
    Or not.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  12. #285
    Sep 2009
    Arnold mo
    Hear something about what? I'm sure I have no idea what you're talkin about.
  13. #286
    Dec 2009
    Buffalo, N.Y
    Didn't make it yesterday but leaving to go this morning, be there at 7 am.
