Page 1 of 5 12345 LastLast
Results 1 to 13 of 60
    Dec 2009
    MIA, Florida
    Question Using swimming pool as water source for heat pump AC?
    Ok so this may be a VERY silly question but I do not know the answer so please bare with me.
    I had a conversation the other day with a friend. He said it was possible to use the water in an in-ground swimming pool as a water source for a heat pump air conditioner? is this in fact possible?
    I am sorry if this is a off the wall question but I'd really like to know.
    Thanks in advance for any replies
    Moved to geo forum
    Dec 2009
    MIA, Florida
    Sorry about that, I realized I posted it in the wrong section after I had posted. Thanks
    Moved to geo forum
    Jul 2009
    Plant City, Florida
    Quote Originally Posted by treepog View Post
    The pool will not have enough capacity, you will overheat the pool, by law a spa or pool can only be 104 degree's F max.
    Nov 2008
    Paradise
    Red face
    Try a septic tank lol.
    Went to a house once where the owner had avoided the considerable trouble and expense of drilling a well (couldn't do a ground loop) for his water source heat pump by using the swimming pool. . It was during the winter and the heat pump wasn't heating well. The swimming pool was a sheet of ice. After my "Here's your problem!" he insisted that it couldn't be the problem because there was still water in the pool. Out of curiosity I chipped through a couple inches of ice, found water, and of course it measured 32F. I suggested he contact the manufacturer and ask them how much heat the unit would produce using 32F water as a heat source. He got the expected response from them and ended up paying us to install 20KW of electric backup heat. He later paid us to install an air-to-air heat pump, after a winter of high electric bills.
    Nov 2009
    Saskatchewan
    In a warmer climate, with solar pool heaters........ You might have hit a niche market here Buck O ......... think about it. You have to be able to switch over to another source.... maybe.
    Dry as a bone Tucson
    pools
    Currently being done by a contractor in phoenix. I am not privy to details but it is a big hit and performs well according to their installers that I have talked to. Here it is
    http://www.dialcomfort.com/blu-eq-ge...ooling-system/
    Watchman Nee
    Dec 2009
    MIA, Florida
    Thanks for the responses.
    Is there a way to calculate how much water would be needed per hour of running the AC? The reason this topic came up for me is that I am looking for an inexpensive way to occasionally cool my shed/workshop not my home. I have a 30'x30' with 8' ceiling workshop at my home and I only use the workshop a couple hours at a time on the weekends.
    Is there a way to calculate how much water you need? Or is it such a huge amount that it would heat a 15''x30' pool to over 100 degrees in two hours?? Just trying to get an idea exactly how ridiculous this idea is I guess
    Dec 2009
    MIA, Florida
    Wasn't able to edit that last post...it's a 15' x 30' in ground pool.
    Quote Originally Posted by ACFIXR View Post
    How many years have they been installing them?
    years?
    dont know but these guys get bug eyed and start drooling when talking about these systems. My take is that thay are a combination type set-up say pool and chiller and an aerator.
    Watchman Nee
    Oct 2009
    __________________________________________________ ______________________
    Hmm very interesting. If this person installed a long enough loop between the unit and the pool it might work. Lets say he installed an underground loop long enough to do the job but only used the pool for the water source and not for heat exchange. He would need 2 loops. 1 before the pool in the series so the ground would do the heat exchange without changing the temp of the pool. The 2nd would be after the pool in the series so the water temp could reach ground temp before entering the heat pump. With a couple of tweaks that might work.
