Results 1 to 10 of 10
    Jul 2009
    In a mechanical room....
    Bad motor install
    Hummm. Something tells me you didn't get the right motor...
    Indiana
    hmmm..that pulley looks odd
    Massachusetts
    Is the driven pulley on the blower healthy? It may be the angle of the shot but it looks like there's no channel for the belt to ride in, like the inner wall has been warn off???
    SC
    Pulley is same diameter as the motor itself! And look at the diameter of the shaft hole. That pulley was taken from a much larger motor.
    They sent a boy to do a man's job.
    Nov 2007
    Whittier, CA
    looks like a "speed me up" Carrier!
    Dec 2001
    Chicago, N/W burbs
    Those take OEM motors. It's a 56 Frame ridgid mount but the shell and stator are backwards. So far, you can only get them from Carrier. They also have an internal overload with external wiring for the control circuit. Our cost is about $320.00 for a 3/4 HP 230V 3PH.
    R2B4BTU
    Jan 2005
    not to mention the half arse controls install.
    "It's always controls"
    Jan 2010
    Levittown, PA
    Wrong replacement motor. Shaft is too short.
    Omaha, Nebraska
    another PITA carrier. I hate the "overload" circuit breaker in those. You have to get the pulley adjustment just right or else you overamp and trip that stupid breaker.
    Thomas aka...spymoocow
    Quote Originally Posted by garya505 View Post
    Ah, sorry I thought that's what he meant. An inch shouldn't make that much difference (at least that's what I always tell my wife).
    Northeast Wisconsin
    Quote Originally Posted by skwsproul View Post
    Par for the course. Those control companies send their own people and I swear they couldn't give a crap about how it looks or how reliable it will be in the long run. Up and running right now is all they care about.
