+ Reply to Thread
Results 1 to 10 of 10
Thread: First Co. w/HW & 3 ton DX Coil
    Aug 2008
    San Clemente, CA
    I should have taken the Chicken **** photo before it was turned into Chicken Soup. Filter is in RAG, boiler system has circulation pump. 3 way valve has inverted flair fittings so one can R&R valve body when needed.
    old unit had a 3.5 ton cooling coil with piston for a 3 ton a/c. Suction was frosting up. Not any more.
    Aug 2008
    Did you just change the Air Handler? Good looking work!
    Aug 2008
    San Clemente, CA
    Yes
    Nov 2011
    Phoenix,AZ
    I would of put sheet metal on the platform for a cleaner look
    I had no idea first co made anything but the in floor apartment air handlers
    Afton, VA / Khorat, Thailand
    Nice looking job...
    Midnight Sun Astrophotography
    Beautiful, Philadelphia, the City of Brotherly Love!
    Filter grill looks kind of small for 3 ton.
    Jun 2010
    Danbury Ct 1/2 hour from NYC
    We use a ton of first cos in Ct for hydro air. Nice install surprised about the r22 unless you changed the exp valve.
    Connecticut
    What brand of condenser?
    And yes, first co AHU's are very common here.
    What is a DX coil exactly? I've heard that mentioned on here before but not sure what it is.
    What is the zone valve doing? I have never seen a 3-port zone valve before.
    Aug 2008
    San Clemente, CA
    The 3 ton condenser was I think a Trane unit, was existing. It really needs to be a 2.5 ton for the condo load so if it ever gets changed out that is what we will do.
    DX stands for the refrigeration cooling coil in the air handler stands for Direct Expansion coil.
    This condo complex has 8 boilers serving several clusters of buildings. The boilers serve the potable hot water needs along with heating needs. Each boiler has a circulation pump sized for the hot water to loop. The 3 way valve allows the hot water to loop around the air handler when no need for heating. Call for heat and the 3 way valve opens the other port so hot water flows through the HW coil in the air handler. The indoor fan is a delay on/off set up with the factory circuit board.
    Connecticut
    Wow I never knew you could set it up so your DHW and heating water were on the same loop.
    Also, curious why you went with an R-22 system?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
