Results 1 to 2 of 2
    Dec 2009
    I need advice - gas insert
    I am a babe in the woods regarding all the features and their benefits. I am hoping you can help steer me in the right direction and get the best use of my money. I am looking at three gas insert models to heat my family room which is about 24 ft by 14 ft.
    1. The Regency Model U32 has 24,500 Input and can be turned down to 16,500. Will 24,500 be enough to heat the room and is the turn down to 16,500 enough of a turn down should the room get very warm? (Just in case you're wondering, the 26,000 BTU doesn't fit my fireplace opening - its a 1/2 inch too short)
    2. The Kinsgman Model IDV33 has an input of 31,000. Is that too high? And it turns down to 20,900. Is that enough? Any other insights into Kingsman?
    3. The Valor Legend G3 has 26,000 but can turn down to 6500 so this is the biggest spread of the 3. However, its about nine hundred dollars more expensive than the other two. It also is battery operated so you can turn the pilot off with the remote control. The sales person says that this will save me money on fuel usage. I think the remote may have a few more bells and whistles to control the heat. The brochure says its "radiant" heat. I don't know how to think about that feature. Any insights?
    Is it worth the extra money to get the Valor? Are the features worth it to get maximum comfort?
    What's the difference between vented, direct vent and vent free and what should I be looking at?
    Thanks for your guidance.
    Nov 2009
    Valor. Hands down. Beauty.
    It is worth every penny.
