Results 1 to 7 of 7
    Nov 2005
    Heat pump runs, but Furnace won't start when it's cold
    My heat pump runs even when it's under 22 degrees. My furnace won't start when it's supposed to. Last night it was about 5 degrees outside and my themostat was set to 68 degrees and the temperature in the house got down to 55 degrees. I can run the furnace using the "EM Heat" setting on my thermostat.
    We got lots of snow which drifted all around the heat pump. I cleared most of that away this morning. Could that have caused the problem? Any other advice on what to do?
    Thanks, Jack
    What thermostat is controlling it?
    Nov 2005
    It is a Honeywell thermostat. I don't know the exact model number, but when I search the web, it looks like the TB8220U.
    If its a TH8320.
    Then its probably just set up wrong.
    Nov 2005
    It has been functioning correctly (I think) for almost 4 years. This problem just started last night.
    Then you'll need a tech to check to see what is wrong.
    Nov 2005
    Thank you. I will do that.
