Results 1 to 13 of 34
Thread: alignment tool
12-09-2009, 07:18 PM #1
- Jun 2006
- miami,fla
- 164
alignment tool
hello everyone, i was wondering what tools do you guys use to align a pump. thanks
12-09-2009, 07:28 PM #2
A Dial Indicator works well
Local 30 New York, New York Operating Engineer
12-09-2009, 07:36 PM #3
- Jun 2006
- miami,fla
- 164
I to use a dial indicator, but what brands do you guys have thanks.
12-09-2009, 08:00 PM #4
Try Starrett, a bit costly but worth every dollar. You will require mounting accessories to enhance performance.
12-10-2009, 12:04 AM #5
I have a 6" pocket ruler I used to get it bumped close, then I throw the magnetic base with a dial indicator on it. Be sure you check not only the up/down and side/side alignment but also the parallel alignment too!
It's not a bad idea to add to the list a micrometer or a caliper that reads in thousandths and a shim kit.
I haven't come up with a good way yet, but I'd like to get a coaxial indicator to use for checking alignment so you can swivel the dial around and see it all the time with out climbing around the pump.
In my machinist's toolbox at home I've got Starret and Mitutoyo for the stuff that needs dead accuracy (which is seldom stuff at work). I've also got a few cheap dial indicators (they are like $20 as opposed to $200) and honestly they work plenty good.
I've got a magnetic base and a cheap indicator in my van. No sense in beating up high dollar precision tools when accuracy under .005" is rarely needed.
VETO PRO PAC, The Official Tool Bag of HVAC-Talk.com
Testo... you guys rule!
12-11-2009, 07:40 PM #6
- Jun 2006
- miami,fla
- 164
Thanks for the great replies.
12-12-2009, 06:35 PM #7
I also use a starett 6'' rule to get close, and then use a dial. I have found that a chain type clamp fastened around a hub with a dial mounted to it and a mirror works very well. I usually have to use 2 to get it mounted. although i see in the link i'm going to try to post now has a 24'' chain. Part # 21025A21 or 2593A11 http://www.mcmaster.com/#catalog/115/2242/=4wlaqn
12-12-2009, 10:11 PM #8
Ya know, I used a chain one a few times back in machinist school, but for some reason completely forgot about them. I might have to pick one up one of these days.
06-01-2010, 08:12 PM #9
06-01-2010, 09:22 PM #10
06-02-2010, 07:43 PM #11
06-02-2010, 08:24 PM #12
06-02-2010, 08:25 PM #13
