Results 1 to 7 of 7
    Nov 2009
    Question Tridium R2 Program block: binary enabled timer
    Looking for a program code to perform a timer function that starts counting up seconds after a binary contact is engaged. Anyone out there done this?
    UK
    Quote Originally Posted by Ctl-fool View Post
    Not simply like that - What do you want to do with the info? You can probably just expose this point from a Binary Input for reference. If you are more specific then we can probably help.
    gnomethang
    _______________________________________________
    "Once men turned their thinking over to machines in the hope that this would set them free. But that only permitted other men with machines to enslave them."
    - The Reverend Mother Gaius Helen Mohiam
    Nov 2009
    Delay on function and seconds since went active
    am looking for a delay-on-make function, and also want to display seconds elapsed since true condition with adjustable time parameter.
    UK
    Hmmm - I have a delay On/Off program object for a Binary State. I could send that tomorrow when I am at the office (21:00 here!).
    You can probably display the elapsed seconds no problem using a reset on the BI - I will check.
    What is the adjustable time parameter for? Alarm after a certain active time? If so the BI can handle that as well, can it not?.
    gnomethang
    Apr 2011
    Pennsylvania
    Question R2 binary "delay on" needed
    Man, I hate to post on such an old thread, but I'm not familiar with the R2 world, and I need a "delay on" function on a binary line.
    I have a BI that's driving an autodialer, and I want to put a one or two minute debounce on it so that I stop getting calls for momentary changes.
    On the existing BI, I see there's a delay setting on the Alarm, but I think that just delays the alarm and not the actual output. I say this because the delay is set to one minute and the emails linked to that alarm don't come as often as the autodialer calls me.
    Jul 2002
    It's under the local library. Look under Tridiumx>programlib>util>BDelay right click, copy, paste
    Apr 2011
    Pennsylvania
    Quote Originally Posted by incontrol View Post
    Wow, that was easy. Thank you for directing me there!
