    Nov 2005
    Laramie, Wy
    Trane Varitrac to AX?
    Is it possible to pull in the Varitrac (CCP3) to an AX? I have pulled in other Trane LON systems but never tried Varitrac. We have three on a comm5 loop along with other controllers and a Tracker. Would like to have a Web enabled front end. Tracer SC doesnt list the Varitrac as an approved device.
    Jun 2007
    Cleveland, Ohio
    Quote Originally Posted by mtnwrench View Post
    Offhand I am going to have to say that you can't do it. The CCPIII is not a LonMark Certified Controller. You might be able to poll the device and make your own .xif but I have no idea what kind of points you would get back.
    I have only heard of a CCPIII being paired with a Tracker. I would be curious to know if this works or not if someone else has tried it.
    There are many jobs that I know of that would work well for such an implementation.
    i have connected to one with Node utility before and all you see is SNVTs with long codes for values nothing that you can work with to integrate as a standard LON device
    Jun 2006
    I was using the ccp tool today and i noticed that it said it was starting a bacnet stack, has anyone tried tying into the comm port on the bottom of the ccp and used bacnet?
