    Oct 2009
    FX40 Discovery error
    I have an FX40 at version 3.0.88 and every time I try to discover any N2 devices, it fails instantly. Is there a way to fix this?
    Mar 2009
    Several Miles from Sane
    Can you "find" them using HVACPro direct connected to the N2 bus ?
    Double check your N2-bus wiring.
    If so, I think there was a patch/upgrade available that may help (Rev 1.1 ?) If I remember right that FX is a rev 1.0. I will check and post more later.
    If sense were so common everyone would have it !
    All opinions expressed are my own. Any advice provided is based on personal experience, generally accepted fact or publicly available information. As such, it is worth exactly what you paid for it, not a penny more not a penny less !!
    NW Ohio
    First get to 3.0.106 as CCI refers to.
    Oct 2009
    now i cant even log into it. I think it finally craped out. I tried rebooting it but nothing happened. I cant ever get shell mode to work anymore
    Oct 2009
    It says "cannot log on using fox" anyone ever get this when you try to log in?
    java.io.InterruptedIOException
    at com.tridium.fox.session.SessionBedroom.sleep(Sessi onBedroom.java)
    at com.tridium.fox.session.FoxSession.sendSync(FoxSes sion.java)
    at com.tridium.fox.sys.BFoxConnection.sendSync(BFoxCo nnection.java)
    at com.tridium.fox.sys.BFoxChannel.sendSync(BFoxChann el.java)
    at com.tridium.fox.sys.user.BUserChannel.fetchPrefs(B UserChannel.java)
    at com.tridium.fox.sys.BFoxSession.connect(BFoxSessio n.java)
    at com.tridium.workbench.shell.BNiagaraWbApplet.logon (BNiagaraWbApplet.java)
    at com.tridium.workbench.shell.BNiagaraWbApplet.apple tStart(BNiagaraWbApplet.java)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknow n Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Un known Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at WbApplet.invoke(WbApplet.java:432)
    at WbApplet.invoke(WbApplet.java:423)
    at WbApplet.run(WbApplet.java:78)
    at java.lang.Thread.run(Unknown Source)
