Results 1 to 10 of 10
    Dec 2009
    Comparison shopping.
    We are planning on building in a community where natural gas runs about $1.50 / ccf (total: delivered and taxed) and electric is running about 6 cents / kwh. The electric is from Niagara Falls, NY and so I'm having trouble finding an upside to the going green or cost / pay back of using Geothermal and / or solar systems in the new construction. The lot has a deep pond with continuous feed from surface water. The location is souther tier of western NY (South of Buffalo). Any comments or suggestions?
    As long as your electric rate is that cheap. Hard to get a pay back on a Geo.
    Sep 2009
    Knoxville, TN
    If your pond is deep enough you can sink the loop in it, which makes the geo alot more affordable than having to trench or go vertical. Plus with the geo you will get a 30% uncapped tax credit which really helps on you ROI
    Nov 2007
    So, if you install a geothermal unit with a COP of ~4, your heating will cost you ~1.5¢/Kw of heat. Nat. gaz won’t cool your house.
    SR
    Dec 2009
    Hummmmmm
    I'd like to see the calculations on how ROI is figured. 1.5 cents (how do you get a cents sign?) is an attractive number if we live there for the next 40 years which could be possible (we're late 40's & earlie 50's) so...
    I know just enough to keep asking questions. Where should I look to get a better education on this before building?
    Get a couple estimates. And ask them for cost pay back/ROI projections.
    Since an air to air. At a COP of 1.5(and that would be a very low COP for a new air to air heat pump) would give you a heating cost of .04 cents per KW.
    You would probably be able to get an average COP of 2 to 2.3 from an air to air.
    Nov 2007
    My 2¢
    Quote Originally Posted by sala7 View Post
    I’m just saying that’s what a kW of heating would cost. Crunch the numbers any way that suits you.
    Regarding "¢", I can tell you how to do it if you’re on a Mac. If you’re on a PC, I’m not sure…
    SR
    Jun 2001
    Louisville, KY
    ALT + 0162
    Perhaps you should have read the instructions before calling.
    Jun 2001
    Michigan
    that 1.5 cents won't stay that way.
    Nov 2007
    Quote Originally Posted by Dowadudda View Post
    Neither will anything else…it’s all relative…
    SR
