Results 1 to 13 of 13
    Feb 2007
    NE Ohio
    Bacnet to ALC arcnet
    Looking for some ideas how to get some bacnet points
    from 3 Carrier Aquasnap chiilers to ALC arcnet. Only need to read
    points.Jace is possibility, but need some specifics as I have no
    experience with ALC. TIA.
    Amarillo by mornin'
    Quote Originally Posted by cal-cu View Post
    Just need to know a little bit more specifics.
    1. MS/TP or BACnet/IP?
    2. Is the interface a LGE or LGR?
    I am going to assume MS/TP and suggest an AMR (ARCNet to MS/TP Router)
    I would think this would be your cheapest and easiest route.
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
    Feb 2007
    NE Ohio
    Frown
    1. MS/TP
    2. LGR
    Amarillo by mornin'
    1. MS/TP
    2. LGR
    Good, if you can get the MS/TP network to the LGR. If not you will need the AMR to add the MS/TP to ARCnet. You will need the USB-K cable to plug into the LGR (only if you connect the network to the LGR) to set the MS/TP speeds, network number, etc. Also, if all you are wanting to do is look at points you are not limited to the point count of the LGR. You use "Display Microblocks".
    Albert Einstein
    Apr 2008
    Madison, WI
    Quote Originally Posted by xarralu View Post
    Yup, it's pretty neat that this can be accomplished through hyperterminal. Just make sure the "enhanced access" dipswitch is in the UP position.
    This also makes me wonder, is ALC the only one implementing BACnet/ARCnet though EIA-485? All other ARCnet implementers (that I've found thus far) seem to use the coax flavor...
    Amarillo by mornin'
    Quote Originally Posted by control_8 View Post
    Looks like Contemporary Controls uses ARCnet twisted but its their own proprietary protocol.
    Albert Einstein
    Feb 2005
    Last time I checked, contemporary controls was who made all the arcnet stuff for ALC.
    Gulf Coast
    Quote Originally Posted by amigo View Post
    You might want to re-check that. I don't believe that has ever been the case. All the ALC is in-house and has dual Comm capability so it can do ARCnet or MS/TP.
    Apr 2008
    Madison, WI
    I know that CC is a big proponent of ARCnet, but I was under the impression that ALC made their own ARCnet implementations.
    I also always wondered why ALC is the only (seems like) one doing BACnet/ARCnet on EIA-485. Don't know if the stack is that complicated, or no one wants to invest the R&D. Don't think it would be a hardware cost, since more MSTP products are going with a communications coprocessor...
    Feb 2005
    Quote Originally Posted by WebCTRL View Post
    I am not talking about the controllers. I am talking about the ARCnet components used in the controllers and/or adapters.
    I could be wrong, but thought my source was pretty reliable.
    May 2009
    Well that might be, I know ALC makes their modules in house, seen their production line. Think they outsource the PCB's and some components though.
    Amarillo by mornin'
    Its both companies
    The companies worked together. Read the following article.
    http://www.automation.com/resources-...s-fit-together
    Albert Einstein
    Gulf Coast
    Yes, this is a laptop connector for talking directly on an ARC156 BACnet network. This from CC but the controller ARCnet items are not from CC.
    Thanks for the link.
