wow...I'm not familure with oil, but isn't 3 gph ALOT?? Don't new ones run like .8?
I had to service this 62 year old behemoth the other day. Old Luxaire coal furnace converted to #2 oil. Could not find a crack at all in that heat exchanger, and I looked real good. It also had a 3.00gph nozzle in that thing. If anything, it's clean and runs great, even if its efficiency reading was 69%.
Not as lean, not as mean, but I'm still a hardcore, ass-kicking, hard charging Marine! Oohrah!
"Just get it done son."
Dad adjusted
3 GPH equates to 420,000Btu@100PSI pump pressure.
Some newer stuff does run as low as 0.45US GPH but with higher pump pressures comes higher BTU.
A large portion of heat from that burner goes up the chimney.
Reminds me of this TV commercial:
http://www.youtube.com/watch?v=ckGOy...eature=related
Here's your sign...
i say they need a new one, but then again i work as an installer at my shop so new ones == work for me
Looks like the one off that Christmas movie the dad likes to cuss out. You know, the one where the kid gets a Red Rider BB gun and almost shoots his eye out.
Last one like that I worked on like that was about 12 years ago. 1951 Lennox converted from coal to oil, I coverted it to gas, flame like the gates of hell. Had a water loop for domestic hot water and base board heat for a finished attic. HO helped in original install, wouldn't let any one touch it but me. Ho said since the furnace and I were near the same age we had a bond, "righht". Pulled maintenace on it for about 5 years. Big crouching rumbling monster in the basement with red eyes. I was allways thinking, "IT WANTS TO EAT ME !"
I thought they only exist on text book and in the museum...
I would not want to haul one of those beasts out of the basement. It can stay there for good with that monster of a nozzle. The biggest nozzle on oil furnace I've ever service so far was 1.25 gph on riello burner...
My parents had a 1927 boiler than ran until the end of last winter. That thing was a monster - 1-1/4" main gas line, 1/8" (?) pilot line, both lines had cutoffs. Ran steam (not hot water), all asbestos insulation, covered ~3600sf. Can't move the bloody thing out of the basement, would have to cut it apart and maneuver it around the new furnace and load-bearing clay-tile wall.
