Page 1 of 4 1234 LastLast
Results 1 to 13 of 44
    Nov 2005
    Unions and pipe dope?
    I was working with an apprentice today and he began to dope the threads on a union. I thought he was joking and I started laughing, and he looked puzzled. He said that he had been taught to dope the threads. Have I missed something? I have been in the trade for 16 years and have never put any kind of thread sealant on union threads.
    Please find me a place where I can find something in print to debunk this notion that you need dope on union threads.
    I STARTED WITH NOTHING, AND I STILL HAVE MOST OF IT!
    Feb 2007
    Southeast Texas
    Thumbs up This works great
    On unions. We spec this out on a regular basis for refinery turnarounds.
    I put sealant on the mating surfaces, way back when, you didn't do this, the unions of today you'd better or expect leaks. Lot of times I just get dia-electrics, just to avoid the problem.
    Today I came across a recently installed compressor, with Blue goop on the roto-locks, just shook my head and walked away.
    I only have to make it work till I retire.
    Denver, CO
    Right here is the only time I've doped a union.
    Nov 2009
    Saskatchewan
    A few fridays, at 5 pm, when I had to reuse an old one that leaked. Tape and dope.
    Madison, Wisconsin
    If you can't find a good enough union from your supplier, it's time to switch suppliers!
    Your just asking to get dope in the gas valve that way!
    I r the king of the world!...or at least I get to stand on the roof and look down on the rest of yall
    Nov 2005
    Thumbs down
    I've looked all over the web, and the only time I can see it is acceptable is with thread lock for vibration. It just seems so wrong. It's like when a see a DIY dope the threads on gas flex lines on his HWT.
    Dry as a bone Tucson
    dope
    Quote Originally Posted by allstar08 View Post
    SOP here for SW gas-does az and Nev, everything gets a lick-mate surfaces and threads,unions and flare ftgs.
    Watchman Nee
    Rapid City, SD
    I've doped the threads before, mostly just to help make it able to be torn apart at a later date. Nothing better than needing 2 36" pipe wrenches for a 1/2" union.
    Rochester, NY, USA
    If you have to put pipe dope on a Union, you ain't doing your job right.
    around here we have to hard pipe furnaces and Hot water tanks, we are not allowed to use appliance hose. except for stoves and dryers. We can't even run CSST to a furnace/HWT.
    "THE LIONS DON'T CARE ABOUT THE OPINIONS OF THE SHEEP"
    Scott Isreal
    Coward County Sheriff ​
    Washington State
    I have never seen one in 32 years in the field.
    earthquakes
    Wait till you get some tremors from a quake, there will be a lot of contractors wishing they would have used a flex connector instead of a hard pipe!
    Watchman Nee
    Rochester, NY, USA
    Quote Originally Posted by ACFIXR View Post
    In western NY it is against code to use a flex connector.
    Trust me, I would use one in a hart beat if I could. It would save me hours of time
    Scott Isreal
