Results 1 to 13 of 25
    Lehighton, Pa.
    Temp output during defrost
    I got a reading of about 65 deg. from my vent during a defrost cycle. Is this an acceptable temp? Seems a little cold to me.
    Dec 2003
    Citrus County, Florida
    what size heat strips do you have? Size of the Air handler?
    Doug
    Lehighton, Pa.
    It's a 4 ton with 10kw
    Dec 2003
    seems a little cold. Pull amp draw to see if all strips are connected and functioning. I've seen units installed with undersized wire and breakers. The installer would disconnect some of the strips so you may have 10KW but only 5 or 7kw connected.
    Doug
    Mar 2006
    The South
    jeepgrady
    I think the other question that should be asked is "why are you even having a defrost call" for the SC coastal area.
    what was outside temp and humidity when defrost call started?
    time defrost or demand defrost?
    TD
    Myrtle Beach, SC
    Bob,
    You have demand defrost with your Lennox XP-16. 65 degrees seems about right with a 4 ton and 10 KW strips. I have had 2 other calls on defrost already today. It was 37 degrees when i got up this morning, it is normal to have defrost during those conditions.
    Kevin
    Remember, Air Conditioning begins with AIR.
    Lehighton, Pa.
    Thanks Kevin. I know about the demand feature. It just seemed 65 was a little chilly when in defrost. If you say it's OK, that's good enough for me.
    You have 48K cooling and 34K heating. Cool air would be expected.
    I don't know
    That's a minimal amount of back heat for a 4 ton HP - I hope you're in a hot climate.
    Lehighton, Pa.
    Read my signature. I'm in SC.
    SW FL
    Question dT =?
    Quote Originally Posted by jeepgrady View Post
    Supply & Return can NOT be the same if the strips are working.
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
    yep
    you're going to have cool draft during defrost..................
    Myrtle Beach, SC
    Quote Originally Posted by dan sw fl View Post
    They can if both the heat and cool are on at the same time, which is the situation during defrost.
