Thread: Need York IOM
    May 2008
    North Texas
    Confused Need York IOM
    Been working on an YCAJ77SU6 Chiller and need data @ oil PSID when starting up after end plate gasket replacement.
    Mar 2006
    Florence, MS
    Didn't see your email address
    Dec 2008
    Dixiana, AL
    J compressors have no oil pressure regulator, they just run wild on oil flow to the bearings (at one time they tried a regulator spring in the motor end bearing housing, but removed it, from what I was told). Net OP will run anywhere from 45 to 90 pounds, depending on operating conditions and mechanical condition of the compressor - have seen it higher, but not often. Trip at 25# net. No IOM's were put out on pdf, but someone may have one that's been scanned.
    Jersey
    you have mail
