Page 1 of 5 12345 LastLast
Results 1 to 13 of 54
    Jul 2009
    Arizona
    coke machine (not cooling)
    Hey guys, I just bought a used coke machine that is not cooling. The compressor makes a grumbling sound like it's stating up for a few seconds then stops. It does this about every ten seconds or so. I'm leaning in the direction of a low charge but I don't want to put ports on it yet until I can eliminate any other possibility. So I decided to get some advice from the experts.
    I'll get the model and serial number tomorrow.
    florida
    Quote Originally Posted by sda View Post
    Sound's like the compressor might be heading south our you could have bad start components.Ya might try a 3-n-1 on it.
    Educational forums are open.
    Jul 2009
    Arizona
    I don't even know what they look like on these things. I was looking for a start cap. LOL
    I'll second the 3 in 1.
    Sounds electrical, but I could be wrong.
    Same concept.
    Jul 2009
    Arizona
    Sorry to sound so lame but a lot of these components are foreign to me. Do these have a start cap built into the compressor, or rather sitting on the side of it?
    Since it's a 120 volt would I wire the cap booster any differently?
    Jul 2009
    I used to manage a restaurant. If memory serves, a coke machine uses practically the same components as a prep table. Anywho, I once had a prep table that would only start for a few seconds and then quit. On the side of the compressor is an overload relay. If your coke machine wasn't maintained, its possible that the overload was tripping quite a bit and wore out (in the case of my table). Might give that a look.
    Jul 2009
    Arizona
    Quote Originally Posted by stebs View Post
    Cool I'll check that tomorrow. I left the machine outside today man These thing's are soooo heavy. LOL
    Jul 2009
    Arizona
    Another things is there's all this tar like substance allover the place. I don't know if it came that way from the factory but it looks like it was used to paint the condenser coil. I would think that would serve to insolate the condenser.
    Jul 2009
    Arizona
    OK it's a
    Dixie-narco
    DNTP 232-8
    0005-2978BL
    R12 8.5 OZ
    10. Amps
    Nov 2009
    Saskatchewan
    You do know no extension cords on those right?
    Got a pic of the tar stuff?? I always try to keep them cond"s as clean as I can! Grease from a fryer maybe? Taste it and let us know. Electrics are on the can ( compressor ) .
    Did you by beers for it yet?
    Jul 2009
    Arizona
    Quote Originally Posted by deux View Post
    I was using a cord! whould that cause these isues or just heat up the cord. I'll get pic tonorrow It's like a tar/paint. black and sticky.
    Apr 2002
    San Diego
    Plug straight into wall outlet and see if it fires up. Extension cords, especially poor quality ones, will have a voltage drop and current gain, not good. Could be the problem. Do you own any quality tools?
    if so, check that start cap. or replace. Next would be replace the current relay. Good luck.
    Pics would help a lot.
