Results 1 to 13 of 68
Thread: Closet Job
01-03-2004, 03:47 PM #1
- Apr 2001
- Camel City, NC
- 6,225
Sorry I didn't take pics of old furnace. Door is 2'6" and old furnace was 27" wide. took it apart in place until we could remove casing with nothing in it. Had to replace floor and level it too.
Be safe not fast. body parts don't grow back
01-03-2004, 09:42 PM #2
Been there, done that. Hope the old one wasn't too sooty.
Col 3:23
01-04-2004, 08:02 PM #3
Very nice closet job.. Nice straight lines,also like the hole through the ceiling for pvc vent(might get hot)...
Nice job>>>(2) thumbs up^^"Everyday above ground, is a good day".
"But everyday that you have made a difference in someones life, may insure you stay above ground a little longer".<aircooled>
01-04-2004, 09:45 PM #4
- Mar 2003
- Washington,NJ
- 504
Sweet Job, disregard any comments from Mr. Don't NoKnow it Alls, keep up the good work!!!!!
01-11-2004, 02:11 PM #5
- Jul 2003
- South Carolina
- 49
Nice looking job very clean and professional looking job. keep up the good work.
01-11-2004, 05:01 PM #6
Banned
- Oct 2003
- Washington
- 7,405
Looks pretty good, except I am pickier than most. First off, I can't stand seeing foil tape. Secondly, I always run BX cable for electrical, romex isn't protected enough, and thirdly, you should do the same with that T-stat wire. Some clamps for the wires and clear silicone for the gaps instead of tape would make it a perfect job.
Josh
01-24-2004, 05:07 AM #7
- Apr 2001
- Camel City, NC
- 6,225
SH
Thanks, but we are not allowed to use silicone. Have to use mastic tape or paint on to seal duct connections and pittsburgh. BX was added to elec. after pic was taken. Steel sleeve was added to gas pipe comming through floor and pvc sleeve to condensate drain so it can't be pushed down and break off at furnace. Metal under cooling coil is not required but my inspectors like it. Have 6 different ones to work with depending on where the job is in the county. AC piping and new condenser to be added in the spring.
01-24-2004, 06:04 PM #8
NEC prohibits running the romex to the furnace like that - it needs to be in some tyoe of conduit (flex, bx, mc, EMT, etc). The means of disconnect for the furnace (toggle switch) needs to also be close by; Mounted on the furnace is usually a good idea. The offset on the RA plenum is also choking the air. Not bad, though.
01-24-2004, 09:33 PM #9
- Apr 2001
- Camel City, NC
- 6,225
Duct offset
I'll recheck my figures on that. It was 19x16 w/1.5" liner, 24" long and 7" offset. 1000cfm @ 650 fpm @.035 friction per 100' of duct. 60k furnace w/ 2.5 ac & 3.0 coil.
01-25-2004, 12:46 PM #10
I mean the offset itself. Measure from the sloped side across at a 90 degree angle (from the slope) and you will see that the duct size has reduced through the offset. Unfortunately, thanks to programmers that don't know about layout, I haven't seen a plasma table that doesn't do the same thing.
01-25-2004, 01:14 PM #11
- Apr 2001
- Camel City, NC
- 6,225
90º
I thought that was what you were talking about. Using my figures I thought there was a little leeway. Yea I've seen the same on cutter layouts too.
01-25-2004, 07:13 PM #12
- May 2003
- Dallas/Ft Worth, TX
- 439
I just did a new Trane XR-80 install at a church and I took tons of pics but I'm not going to post them here and have every armchair HVAC installer tell me how crappy it looks. You did a good job and I'll bet the Homeowner is pleased which is all that matters. I wish I could do sheetmetal work like some of you guys.
01-25-2004, 07:17 PM #13Please post the article and section of the 2002 NEC that you're interpreting.Originally posted by sadlier
