Results 1 to 4 of 4
    Nov 2009
    Continuity check on Fluke meter
    Hello all. First time post. I use a Fluke 16 meter, sometimes when I am testing continuity I get 1 short beep, not the continuous beep when you have a circuit. Other times I get nothing, so there is a purpose for this short beep, can someone help me with this? Thanks
    Denver, CO
    The short beep indicates continuity with low ohms. When your ohms goes over 25 on 250 off on a fluke 16 it won't beep. Your batteries may be low, or you might have a poor connection at the probes. I would suggest putting it in ohms and not continuity check and then watch your numbers and see what you get insted of useing the audio indicator.
    houston, texas
    I agree, use the ohms scale instead.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    florida
    Quote Originally Posted by Texas-Tech View Post
    x3
    Educational forums are open.
