Results 1 to 13 of 13
Thread: new burnham
    in a house, Appomattox, Va.
    Put this in a few weeks ago. Had to pull out old through door behind boiler and slide new in over framed opening and baseboard.
    New boiler definately was cranking out heat- the new paint started to blister off pipes after 15 minutes, cheap paint, I guess.
    [Edited by bcw on 12-29-2003 at 10:06 PM]
    Col 3:23
    Dec 2001
    Chicago, N/W burbs
    Blue pipe dope, is that LeakLock® ?
    Also flue pipe looks off kilter and the damper is missing. Otherwise looks like a fine install in a tight space.
    R2B4BTU
    The pipe is tilted to the back in order to clear the header, there is a regulator on the left side of pipe just before it goes in thimble, it blends in with the pipe. The pic is a bit fuzzy.
    I believe it is leak lock- little silver can w/brush on cap.
    Col 3:23
    May 2003
    VA
    just curious what is the application here?
    Thanks.
    steam boiler, one pipe system
    Col 3:23
    Monmouth Junction-NJ-USA
    That's not leak lock. We use it very very expensive but good. Almost the same color though. Cant think of the name of it. It is a pain to get off your skin, just like leak lock.
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Washington
    One of my colleagues uses the blue form of pipe dope. Works well for him, not sure if it works better than your standard rector-seal. I do know that it costs more though. It seems to go on a lot cleaner too. Hmm, maybe I just convinced myself to start using it.
    Josh
    oil-2-4-6-gas is offline Professional Member b&M _email server rejected
    thats blue block it gets everywhere and it is fun to get off
    pilot is offline Member- bad email - server kicked back
    Apr 2003
    alb new york
    Megalock?
    Am I not seeing the barometric damper on the flue breeching? (oops someone already said that)
    [Edited by benncool on 01-05-2004 at 01:48 PM]
    Apr 2001
    Camel City, NC
    Bubbler
    Looks nice, Bet they are supprised how well it heats. That oil bill will drop 20%+. didn't have much space to work with. Hows your back? Nice to see red clay in a pic.
    Be safe not fast. body parts don't grow back
    Nov 2003
    FYI, the barometric damper is supposed to be located as close to the appliance collar as possible. Also, where is the code required cleanout? Looks like it got bricked up. You just might meet the 18 inch clearance off the chimney connector pipe. If that pipe is greater than 6 inch, it must be 24 gauge. What is the sidewall clearance to that combustible wall?
    Doc
    A cleanout would be nice, but almost all the chimneys I see have no cleanout, and cannot be insatlled in many cases. There's 2' to bottom of flue from smoke pipe, so it would take a lot of soot to block the flue, and we pull the pipe during flue cleaning, anyway.
    The damper is close as possible, since the bacharach thermometer cannot be in line of sight with hx, but around the bend in ell.
    Col 3:23
