Results 1 to 13 of 14
    Dec 2006
    philadelphia pa
    reach-in lite problem
    This may be a stupid question but, working on a reach-in today, no lites so I replaced the bulbs, still no lite. So I replaced the ballasts, still no lite. PLEASE LET THERE BE LITE!! Is there any way to check the ballasts and or tubes? 120 volts present at the ballast. I tried to check voltage at the socket, top and bottom =0 volts any ideas?
    Feb 2007
    Northern NJ
    are the door switch contacts working properly?
    Nov 2008
    S.C.
    I'm wondering if there is anything else in the circuit. Like a little miniature aluminum can looking gadget? I think its a starter if I remember correctly. (or something like that)
    Quote Originally Posted by oldtimer2 View Post
    I look for dark spots at the ends of the tubes.
    Also use a NCV tester to check for potential at the lamp ends.
    Some units have a thermostat running the lights
    Dec 2006
    philadelphia pa
    I didn't see a door switch
    4 door reach-in, the lites on the left side are working
    on the ballast, should I be able to read potential at the leads? 4leads for each lite
    I've had bad connections/loose wires at the bulb sockets before that will drive ya nutz like this.
    Nov 2009
    Saskatchewan
    You have to also watch the bulb output HO or VHO ???? One works in the cold and one doesn't.
    And what the others said about the starter. Unless they are electronic. Somedays you need 20 new starters find one good one. Watch for new duds in the starter area.
    Nov 2008
    The only thing left besides the starters are the lamp sockets, the "tombstones."
    Also make sure the index mark on the tube ends shows that the tube is fully rotated into the socket correctly.
    On tubes with two pins on the end, there should be a few volts across the pins to heat the filament.
    Also, some lamps don't start reliably unless the metal Ground Plane (the metal case) near the tube is grounded.
    NorthWest
    Some reachins have the door switches in the door hinge.
    Nov 2009
    Saskatchewan
    I checked today. You still can buy a *wand* from any bulb supply house to check output.
    I have one, but haven't used it for decades. I got snagged up on VO and HVO BULBS once and it drove me nuts. The wand didn't help with that VHO issue.
    Nov 2008
    Quote Originally Posted by deux View Post
    I think these non-contact testers trade convenience for False Positive or non-repeatable readings. And almost all contact voltmeters respond to Phantom Voltages.
    Jul 2009
    Connectitaxed
    Quote Originally Posted by thethomas4 View Post
    If this is a Traulsen that is an issue. make and model of unit and the answer will be easier to figure out. ballasts can be a pain to understand even for an electrician.
