Results 1 to 13 of 19
Thread: Need new gas Furnace....
11-17-2009, 06:42 PM #1
- Nov 2009
- 4
Hello....
I live in Indiana and in need of a New Gas Furnace!!!! I have gotten some prices on Bryant,Trane and Carrier 95% gas furnaces with and w/out Ac units.
Anyone have any Good/Bad thoughts on these brands
I have 1100 sq ft house with the Ducting running though the slab.....80,000BTU is what I have been quoted!!!!.....
Any Help will be appreciated...Thanks
11-17-2009, 06:45 PM #2
sounds like my house...u living in my closet?
anyways....most the pro members here will tell u..Its the quality of the install that makes a good unit. Bad install future problems will arise. Professional clean install and your unit will last and last.
11-17-2009, 08:24 PM #3
How did they determine size?
I have 1000 sq ft, ducts in the crawl. Really need about 45K but 60K 95% was smallest made in my brand with 2 stage and variable speed blower. I have a manual switch to keep it off high fire. Low at 39K does just fine. High is noisy due to the amount of air the furnace needs to move. I can't fathom putting 80K 95%er in 1100 sq ft. If it could move enough air, it would be LOUD. If it couldn't, it would overheat and possibly lockout or the limit would stick open, both leaving you without heat. We did a 3000 sq ft house today with a 90,000 BTU 95.
11-17-2009, 09:33 PM #4
Sounds like a bit of an oversize.
Where are you located. Do you have lots of windows.
11-17-2009, 09:44 PM #5
Watch with sizing because ducts might not handle Cfms on furnace. 80 000 seems likes it over sized in my neck of the woods Alberta where are ambient temps are -35.c so I can only imagine in your area. I would agree with Op. Look at pricing and Branding second and go with gut instinct. Shop Chinease or made in Mexico!
Do it right the first time.
11-17-2009, 11:31 PM #6
Goodman is great! Has to be installed properly though. Get prices on goodman GMH and GMV models, both are 2 stage.
11-17-2009, 11:54 PM #7Do it right the first time.
11-18-2009, 06:20 AM #8
Yea, it's great to make a 2 stage furnace that can't use a 2 stage stat
11-18-2009, 06:29 AM #9
- Nov 2009
- 120
I have put all three brands in. All three are great furnaces and are quality made. Im a Trane guy personally, but if I were you, if there is a Lennox dealer in the area, I would get a quote on a Lennox G71, also a very good and very quiet furnace. Plus it has a DC drive blower, so your using less electric, and qualifys for the tax credit. Just something you may want to think about.
11-18-2009, 05:40 PM #10
MOVED INTO RESIDENTIAL!
11-18-2009, 07:21 PM #11
- Nov 2009
- 4
OK.....
I am looking hard at the Bryant Model 355cav042080 95% 80,000 BTU or the Carrier Model 58HDV0801-20 95% 80,000BTU Furnaces......
Any thoughts??????????
11-18-2009, 07:31 PM #12
Their both oversized.
Will probably trip on limit. And cause you a lot of no heat situations.
11-18-2009, 07:39 PM #13
