Results 1 to 13 of 17
Thread: A hot shower
    IN THE CRAWL SPACE
    A hot shower
    Is this normal Norman?
    Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
    Nov 2001
    east kansas
    I have lights over the showers in my rental. An electrician installed and city inspector passed. You need ones approved for that location.
    Beware of advice given by some guy on the Internet.
    IN THE CRAWL SPACE
    Quote Originally Posted by Milk man View Post
    What does it take to make it safe.I was thinking something like the type
    used in swimming pools?
    Nov 2001
    east kansas
    I don't know. That's why I hired an electrician. Only failed one inspection the whole project. That was because the area had a stricter code than the electrician was used to guarding the placement of the panel and the meter can.
    IN THE CRAWL SPACE
    The reason I'm asking is because its in my girlfriends house.I want to make it safe.I'm tired of taking baths LOL
    Atlanta GA area
    The only light fixture I know of that is approved for a shower is a can lite with a gasketed lens. That exposed light is definitely NOT approved... however... unless there was a stream of water between you and the light fixture, you probably will not have hair standing straight up after a shower...
    Would it be possible to install a 'shower approved' can lite in the ceiling? I think they have them at HD and Lowes...
    GA-HVAC-Tech
    Jul 2009
    I used to have a shower light in the shower at my old house. It had a base similar to the one in the photo, but it also had an acrylic or plastic enclosure that screwed into the base and covered the bulb, and if memory serves, there was also some sort of gasket in there as well.
    I'm also not sure that electrocution is the only thing to worry about in that picture. i'd be concerned with the relatively cold water hitting the hot glass of that bulb and causing it to shatter.
    NY NY
    NEC 410.4 (D) allows lighting above a shower with exception. Your local code may interept the NEC differentely.
    Urbandale IA. USA
    What if the light is on a circuit with a pannel mounted GFI?
    I agree that light would be riskier than most....
    Those who dance, appear insane to those who do not hear the music.
    Those who believe, appear ignorant to those who do not know God.
    Atlanta GA area
    Quote Originally Posted by cehs View Post
    Theoretically, that would deal with the shock hazard... however;
    What about the broken glass issue?
    I think you would be better with the can lite IN the ceiling.
    GA-HVAC-Tech
    Indiana
    cant tell much from the pic...include one of said girlfriend and i may be able to help more.
    IN THE CRAWL SPACE
    Quote Originally Posted by yellowirenut View Post
    Here you go MR yellowirenut.
    Nov 2009
    Cincinnati, Ohio
    Ideally, simulating actual showering habits...
