Results 14 to 26 of 34
    Nov 2009
    what if they are configured for the " CHHN " compressor like what is in the unit. can u think of anything else?
    Nov 2009
    I took extra time on this chiller to make sure the coils are clean. Fans do work and right direction. Head pressure is around 200 psi
    ottawa canada
    Well if the config is right ,the coils are super clean ,the sat condenser and oil temp sensors are correct then it would have to be dirty oil filters ??
    Nov 2009
    pressure drop across oil filter is 4 psi
    N.E. IA
    Quote Originally Posted by Dave_87 View Post
    I can't remember the exact lettering of the compressors. I think there are only two models. Ours were configured for the opposite compressors than were actually on the machine.
    It was a situation where we took over a contract when the chillers were a couple years old and then mysteriously they started having this "Oil Control Fault" problem. How do you suppose that happened? You don't think the previous contractor was a little disgruntled they lost the contract?
    Just like you, they would run for several hours, and then when they'd cycle off the alarm would show up.
    Chillrdude explains exactly how it works. The controls test for oil pressure control integrity at each shut down.
    Go through the entire configuration and make sure it's configured for the machine you actually have.
    "Wheel" mechanics work on "Wheel" chillers
    Nov 2009
    Ok. I'll go through the configs again. Your right there are only two " CHHN and CHHB".
    N.E. IA
    That's it.!!! Been a while. This one was configured for CHHB when it actually had CHHN compressors. Gotta read the diagnostics word for word. Some times what you think you're reading, isn't what it's saying.
    Good luck and let us know what you found out.
    Nov 2009
    I'll check it in the morning and let ya'll know.
    Nov 2009
    You was 100% correct. I give you an adiboy!!!! Thank you so much for you help!!! Configured for 200 ton chiller and chhb compressor.
    ottawa canada
    Moral of the story....... post the exact information and readings and you will get to the root of the problem much faster .
    N.E. IA
    Quote Originally Posted by graham View Post
    Actually, He did in his very first post. We just didn't read it correctly. Sometimes what you think you saw, isn't always what's really there.
    RTAA 1254 trane chiller
    unit is going off on "oil flow control" both compressors. unit does not have oil flow control or oil pressure switch. it is monitored by temp. thermistors. This diagnostic code is not in the book. Does anyone know what this is?
    ottawa canada
    Your right he did . Sometimes you cant see the forest for the trees .
    East of big city prices.
    Come on you Trane guys yall are slipping a little bit on this one !!!!
