    Nov 2008
    Paradise
    Field control draft inducer on oil fired boiler!
    has anyone ever installed a draft inducer made by field control, on oil fired boiler? Just wanted to know if they work good. I have a Weill McClain that has no draft over fire, but -.03 at the smoke pipe. The boiler is not sooted up I just cleaned it. The building is under negative psi or chimney is under sized.
    Yes.
    And when you get pro status, and post this in the pro forums.
    We can go over it then.
    Nov 2008
    Paradise
    I'm still waiting for them to get back to me it might take a month or two. Anyone else just want to know how well they work.
    Or. It could be later today.
    Nov 2008
    Paradise
    Do you have a lot of oil were you live? Or gas?
    Lots of oil. More oil companies in this area then I can remember. Worked for 2 of them for over 12 years.
    Nat gas and oil in the city, and also LP in the suburbs.
    And I've used field controls draft units already.
