Thread: NO NO NO
    IN THE CRAWL SPACE
    NO NO NO
    When will guys read the install instructions.
    Love how they just stubbed into the old double wall.This water heater requires proper venting or the water heaters
    heat exchanger will clog up!!!!!You can not vent these straight up and can not increase the flue pipe size on the way out.
    Poor little feller never had a chance with this brainac's venting
    If you look at the installation instructions they clearly state that you cant vent them straight up as well as other things.
    http://noritz.com/u/installation_man...1321m_asme.pdf
    Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
    IN THE CRAWL SPACE
    Page 12 of the PDF shows how it needs to be.
    Oct 2009
    that mouse must already be smelling bad by the time you took the pic.
