Results 1 to 9 of 9
    Nov 2008
    Paradise
    Aqustat for steam heating?
    Yes you use an aqustat for steam heat only if it's providing hot water or tapped off for hot water baseboard in the basement I've seen that too. I only am using it for the steam heat. Thats what the psi switch is for it shuts down the burner. thanks
    Altmar, New York, United States
    i just logged on here , did i miss something?
    Jan 2003
    Silly rabbit you don't use an aquastat, you use a humidistat to control steam....
    If your looking to gain LEED points use Co2 to control it...
    ok still confused. are you teaching us a lessen or testing us? maybe it's just me. i know it's early and i have had a few but it was one of those days and my last job was at a tavern.
    Howell, Michigan
    Okay! Where are we going with this?
    Nov 2008
    Paradise
    relax I was trying to talk to ccikelly on my post you locked out. Do you have something useful to say if not let the adults talk.lol
    Howell, Michigan
    Quote Originally Posted by Vinpadalino View Post
    I am the last guy here you tell to relax.............a little respect and a lot of rules following goes a long way.
    At this point, you are done attempting to skirt our rules. You need to apply for Pro Membership, then you can post your questions in the proper forum.
    You are posting this in controls, it's the wrong forum.
    Follow the rules, be respectful to each and every volunteer that helps run this website or your account will be removed.
    to enjoy this forum to its maximum:
    Look under the name of whom you are directing you comment, if it states MODERATOR, you may want to rethink the comment you are about to post
    beyond that knock yourself out and don't get your panties in a wad when somebody tells you what you can do to yourself.............whether it's physically possible or not
    You wanna talk steam. Wait for your approval for pro membership. Then you can talk about it in the pro boiler forum.
