Results 1 to 13 of 20
    Nov 2008
    Paradise
    Steam boiler controls???
    Does anyone know what controls a oil fired steam boiler? What controls the temperature, and does the low water cut off come build on to the boiler?
    Mar 2006
    Quote Originally Posted by Vinpadalino View Post
    Dude ...you do not need to be within 10 feet of a steam boiler.
    Howell, Michigan
    I agree, this is not a DIY site. Call a contractor!
    By your profile, your in the trade.
    Sorry, this is not a DIY site. So we are not allowed to give out advise of this nature. In the open forums.
    Since answering your question in the open Residential Forums would be posting instruction for DIYers that may read this post later.
    You have the post count., apply for Pro Membership.
    Use this link Apply for Pro Membership
    Once accepted, you have access to the pro tech forums. Where you can ask and get answers to technical questions.
    Plus, you also have access to the Pro Educational Forums.
    All of it is free.
    Thank you, for your cooperation.
    We have boiler forums, where these questions can be answered in detail. But you must be a pro member to access that forum.
    Dang. Took me 3 minutes to type that.
    Howell, Michigan
    BT, thanks, it's hard to do that from a BlackBerry
    Quote Originally Posted by HeyBob View Post
    No problem.
    Mar 2009
    Several Miles from Sane
    Hmm
    3 minutes ?
    It looks just like the last umpteen dozen you put on all the other threads...... or am I just dreaming ? (AIGF)
    Thanks for being there though.
    If sense were so common everyone would have it !
    Any advice provided is worth exactly what you paid for it, not a penny more not, a penny less !!
    Quote Originally Posted by CCIKelly View Post
    3 minutes ?
    Ok, I might have been exaggerating.
    Actually. I have 2 different versions of that.
    Nov 2008
    Paradise
    OK Thanks any way. There must be an Aqustat control that is set at 212 degrees, that shuts the burner off. I'm guessing the low water cut off is mounted on the boiler too. The thermostat is wired to TT on the primary control. I'm only asking because there is only about 1 in every 100 houses that have steam were I live.
    Follow my instructions in post 4.
    After you are accepted.
    You can ask in the pro tech forum. And find out before you harm someone.
    Because you don't know how steam boilers and their controls work.
    Nov 2008
    Paradise
    All of it is free.
    What is a DIY site?
    Do It Yourself.
    Meaning, home owners that do their own repairs or installs instead of hiring a contractor.
