In programming on the KMC, the word CON is used as con4, con5, etc. I cannot find the definition on what it is used for, can anyone help?
con refers to 'CONtroller' - PID loop
"Controls is a lifestyle not a job" -klrogers
If you are using WinControl, select "Control" from the menu bar and then "Controllers" from the sub menu.
UA LU 562
If you are using the KMC software to view the program, just double click on it. The point's details will open up. Works for everything but keywords and local variables if I remember right.
Forum Rules
