Thread: YCAL HPCO
    Aug 2009
    Seattle Area
    YCAL HPCO
    Does anyone know whether or not the HPCO has a shrader under it on a YCAL?
    Somewhere in the world.
    It should have one in there but in the past I have said the same thing and found none , most likely its there.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Aug 2009
    Seattle Area
    Thank you. I'll let you know if I get surprised.
    Jun 2009
    Florida
    Quote Originally Posted by NWMech View Post
    Isn't there an ASHRAE standard or rule that states there can't be any shut off device on an HPCO? And I think it includes schraders too. Most (if not all) of the recips and screws I've worked on haven't had one unless someone added one. And usually it's a flare fitting that you can't put a core in anyway. I'd be very careful and at least isolate the discharge line and get the pressure down a little.
    Low Pressure Forever!
    If you know heavy metal, you can work anywhere-Dave Andreson
    Anchors Aweigh my boys, Anchors Aweigh!
    Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
    The switch that he is refering to is barrel style with a depressor inside of it female flare to male flare upon removal of the switch you will lose a small amount of freon if your quick but that it other wise there is no other way to replace unless you take all the freon out there is no other way to isolate to replace.
