Results 1 to 13 of 14
    Oct 2008
    Difference between 13 and 16 SEER
    Hi,
    We are looking at Bryant systems. According to the tech who came out, the space where our old unit is located is too small to contain the equipment that would bring us up to the 16 SEER, 13 EER rating allowing us to receive a tax credit. (We live in a curious house and changing this location is prohibitively expensive.) He did however tell us we could still get a 16.5 SEER unit that would save us a lot more on energy costs than going with a 13 seer unit.
    We're on a tight budget and would totally go with the 16.5 SEER route if the tax credit were in play. Since there's no credit for us, however, we really need to weigh the options carefully before we spend the extra $$.
    My question is twofold . . .
    Is the 16.5 SEER unit even going to operate at a 16.5 level without whatever is required for the 13 EER rating? Would it be like purchasing a car that can go 100 miles an hour, but never going faster than 55? (The 16.5 unit he's quoting is 2-speed with Thermidisat, the 13 unit is single with Honeywell 6000.)
    How does the difference in efficiency between a 13 SEER and 16 SEER unit translate to utility bills considering that the 16.5 SEER unit won't be 13 EER?
    Thanks so much!
    Gracie
    SW FL
    Question 2. 16/ 13 = _ _ _
    Quote Originally Posted by peacecorn View Post
    1
    2
    Gracie
    1. Probably going to be a bit shy of the rating
    2. ~ 20%
    Designer Dan
    Depends on what area you are in.
    Oct 2008
    Thanks for the info.
    I'm in Florida, so there's humidity to consider.
    A VS blower will help with humidity some.
    A 2 stage outdoor unit helps even more.
    but if you don't have room for one. Then, have your contractor/contractors match up an indoor unit that provides good moisture removal. Not all coil match ups remove the same amount of moisture.
    West Palm Beach
    There are many systems on the market, I am pretty sure you can find a unit to meet your financials, and the space you have.
    If you post the size of the space you have here someone might be able to help.
    Jun 2007
    Round Rock
    I think I might shop around a bit more. Honestly, physical unit sizes in the same tonnage ranges aren't much if any much bigger for an increase in seer. You must have a very small area if so.
    I like DIY'ers. They pay better to fix.
    Nov 2000
    Eastern PA
    As stated, we need to know your parameters to help you. What models of equipment are currently being discussed? What size area do you have to work with? Going to a heat pump may actually wind up costing you less to install because heat pumps don't need to be as efficient to qualify for tax credits. You would then also have the benefit of saving on your heating bills. In Florida, you probably wouldn't even need to use auxilliary heat.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Oct 2008
    We did shop around a little bit--we live in a small FL town and there aren't a lot of options. The Carrier people were exceedingly flighty and wouldn't provide us with any specifics. The day they arrived, they told us we'd qualify for the tax credit, but only after repeatedly calling them back, did they tell us that we didn't. It was as though they didn't want to talk to us because the space was too small to afford the system they wanted to sell so they gave up.
    In turn, we gave up on them.
    At least the Bryant people were up front about not receiving the tax credit and have been responsive to our questions.
    Anyway. The width of the door on the closet where the current unit is 15 inches. The width of the closet is larger than that and there is appears to be a 17 inch piece of ductwork on top of the existing unit. The depth of that piece is way less than 15 inches--that must be how they got it in. (We live in a geodesic dome, space is tight.)
    Could there really be a heat pump option with so little space? We'd love that! The Carrier people told us flat out NO. (I will ask the Bryant people about it in the morning.)
    Thanks so much for all your help!
    Oct 2008
    I call BS on this whole thing.
    Ok, that closet sounds small, but even if you had to open up the door framing to get it in, doesn't sound like a huge issue.
    What about a minisplit? Maybe a ducted style minisplit?
    Can you post some pictures of how this space and arrangement is?
    Nov 2000
    Eastern PA
    I thought you were saying the outside area was too small.
    Yes, I have run into situations where the interior unit space is not large enough to accomodate a variable speed blower unit that is required to receive tax credits.
    Since you do not have space for the larger variable speed indoor unit, you also cannot have a two stage system. The best you can do is to get the highest SEER rating available without the variable speed blower, which is why you will be sacrificing the EER rating.
    Apr 2004
    what's the tonnage? Did I miss that?
    Bay Area, CA
    Quote Originally Posted by RoBoTeq View Post
    Depending on tonage and product line, you wont sacrafice to much eer rating when you drop the seer of the system, its not like a 1 for 1 drop. A while ago a few american standard 15 seer single stage units would have a better eer rating then the 16 seers. Multistage cooling systems dont help eer ratings.
    Global Warming or: None like it hot
    No pleasure, no rapture, no exquisite sin greater... than central air. -Dogma
