    Western Wa
    Ananlog out to binary out converter gadget?
    I need to come up with way to have a binary output with adjustable on/off riding on a 0-10VDC output.
    Does anybody know of a DIN rail mounted gadget that would do this?
    Thanks...
    God Bless our Veterans
    God Bless the USA
    San Francisco Bay Area
    http://www.kele.com/Transducers/Mult...s/UCS-121.aspx - I've used these with good results..
    Feb 2005
    Where it's dark & damp
    If you mean you need to control a binary device from an AO you can use any of the following.
    Honeywell makes just such a device that is DIN rail mounted.
    http://europe.hbc.honeywell.com/prod...a/pg_mce3.html
    Functional devices has a ton of relays that will pick up off of 10vdc. The comon RIB relay is one of them. They also have track mounted ones if you want to install them in a panel.
    http://www.functionaldevices.com/pdf/RIBMU1C.pdf
    They also have multiple relays off of one AO that will pull up certain relays at specific volatges.
    http://www.functionaldevices.com/pdf/RIBMN24Q2C.pdf
    If you need to be able to adjust the pick up and drop off voltage I would buy the device mentioned in the post above. You could also use a sequencer for the purpose as well.
    NY
    Not sure what you mean by adjustable on/off. Why not just program the output to be at the relay voltage when you want it on. For instance: If PID = 75 then AO = 12vdc else AO = 0vdc. This is assuming your analog outputs are 0 - 12 volts.
    "Controls is a lifestyle not a job" -klrogers
    Jul 2002
    Has anybody run across adjustable relays that DO NOT need operating power. I have a couple things to control on an existing 2 conductor to the roof and there is no where to get power.
    Western Wa
    It's a Mickey Mouse way to cycle on a spray pump and tower dampers on what is intended to be a cooling tower bypass. The "control contractor" left it with just a common solid state relay doing the switching, and at certain combinations of load and ambient, the relay "stutters".
    God Bless the USA
