Thread: Carrier 30gt liquid chiller.
10-31-2009, 01:05 PM #1
New Guest
- Oct 2009
- 2
Circuit A of the above mentioned chiller is not working but the circuit B is working properly.In quick testing the thermisters are ok and the EXV is opening and closing and the compressors are also ok but in normal working the EXV is not opening.The alarm indicate code 68.
pls suggest a solution??
10-31-2009, 04:23 PM #2
quick testing of the sensors only show open or shorted sensors. They could be way off. you need a manual for this chiller and study it.
10-31-2009, 06:02 PM #3Low Pressure Forever!
If you know heavy metal, you can work anywhere-Dave Andreson
Anchors Aweigh my boys, Anchors Aweigh!
Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
11-01-2009, 12:49 PM #4
New Guest
- Oct 2009
- 2
The inlet connection in circuit A and circuit B of the cooler has an oil and refrigent leaking due to rust.Can we change the cooling head or the inlet pipe to solve this problem or is there any other measures.
